2011 Prius Radio Display Screen Flaking Out!
Discussion in 'Gen 3 Prius Audio and Electronics' started by dannybjax, Jun 20, 2021.
  1. dannybjax
    dannybjax Junior Member
    Jacksonville, FL
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Probably a loose connection or water / moisture got behind and into the connections ;).
    Our old 2010 would occasionally have a wonky display, so I pressed on it hard and it would reset:).
    Might not work in all cases, but it worked in our situation:whistle:.
    Good luck and keep us posted(y).
  3. dannybjax
    Jacksonville, FL
    Thanks Ray! What did you press hard on? The actual display itself?
    52,822
    i hope so :oops:
    Raytheeagle likes this.
  5. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Yes;).
    Push in all four corners:).
    Hope it works for you(y).
  6. dannybjax
    Jacksonville, FL
    It actually didn’t make a difference but it’s an excuse to buy a new Android head unit :)
    iPhone ?
    bisco and Raytheeagle like this.
  7. ChapmanF
    19,008
    There's a thread here somewhere from a member who found the display panel for cheap and replaced it.
  8. Mendel Leisk
    42,323
    Finding it HARD to find anything but the larger screen style display. Our Canadian 2010 Touring is similar: no large, nav-style screen, JBL audio. Maybe I need some coffee...
  9. dannybjax
    Jacksonville, FL
    Bought one on AliExpress. I’ll post pics of it. Still struggling to get it wired in properly
    iPhone ?
  10. Mendel Leisk
    42,323
    I happened to use those guys for first time recently; got a bayonet lens mount. The world is getting smaller.
  11. ChapmanF
    19,008
    Those videos sure look like it is stuck in a display test of some sort.
