2011 prius slip indicator light always on
Discussion in 'Gen 3 Prius Technical Discussion' started by ilovetoracecross, Feb 15, 2020.
  1. ilovetoracecross
    ilovetoracecross Junior Member
    39
    southampton
    Hey guys. Long post.. sorry
    So my horn in the 11 prius stopped working. Ish. It worked at certain positions on the wheel leading me to believe a clock spring failure was the culprit.
    Replaced clock spring. First with a Chinese one. Went through several to get one that worked, eventually going to a refurbished/wrecked oem unit.
    Trouble is, now the slip indicator is always on. Techstrean says "c1231 steering angle sensor circuit" clicking on it says "malfunction present DTC (S305-12).
    Any ideas? Or a diagnostic chart if I have to pin it out to isolate the problem? Thanks
  2. ChapmanF
    18,954
    Was the steering angle sensor still attached to the clockspring you most recently put in, or did you transfer it over from your original? Was the steering shaft straight and the sensor straight when you put the clockspring on? Are the connections secure?
    If all the simple stuff is checked, then the repair manual troubleshooting steps for C1231 would seem to be next.
  3. ilovetoracecross
    39
    southampton
    Connections good, dont think there is a blown fuse. A little uncertain which fuse it could be. Sensor is part of the clock spring (i suspect, there's a plug only as part of the loom) so it's new with the unit.
  4. ChapmanF
    18,954
    I think the sensor is detachable from the clockspring, though the manual recommends that you don't. With the number of clocksprings you've gone through by this point, it sounds like you might have a sensor or two you could try, if the one that's in there doesn't cooperate.
    Have you caught up with where to get the manuals so you can follow the C1231 troubleshooting?
  5. ilovetoracecross
    39
    southampton
    No, can you link me the manual?
  6. ChapmanF
    18,954
    Click on the words that are blue.
