2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Well this started with small noise and got progressive pretty quick. Kinda stumped me becouse 301 misfire cylinder 1 came up at similar time.
    So it is heavy knock noise that goes away fairly quickly. It happens after it has been sitting for a few minutes. Like after battery has drained and it starts up to charge battery.
    See attached video
  2. Mendel Leisk
    42,355
    Engine coolant level stable? How many miles? Ever cleaned the EGR?
    PriusGuy32 and Raytheeagle like this.
  3. Mendel Leisk
    42,355
    The car can be more prone to do this, if you did a cold start, and quickly shut down, then it sits, say overnight. Why nobody's sure.
  4. Raphael Muscarelle
    661
    222
    240k miles was cleaned at 180k. I had egr tube off and it was fairly clean.
    This does this within 10 minutes of engine not running. Not long sit.
    It started with like what sounded like 3 knocks from a CV joint. But it quickly became apparent it wasn't a CV joint.
    codes in attached images. Computer is saying random misfire. Screenshot_20191005-100857.jpeg Screenshot_20191005-135516.jpeg
  5. Raphael Muscarelle
    661
    222
  6. Raphael Muscarelle
    661
    222
  7. Raphael Muscarelle
    661
    222
  8. Raphael Muscarelle
    661
    222
    I think Toyota came up with a fix for the similar problem when it is cold 40 deg.
    I'm in Florida where it hardly gets 40 at night maybe 2 weeks out of the year.
  9. Mendel Leisk
    42,355
    Was the tube as far as you went? With 180K, I'd think the EGR valve, cooler, and the intake manifold EGR passageways, will all be moderately coked up.
    The head gaskets seem to be going, with monotonous regularity, between cylinders 1 and 2.
    mjoo and The Critic like this.
  10. Raphael Muscarelle
    661
    222
    I only looked into the tube. I'll pull apart the rest of egr tomorrow. Or so.
  11. Mendel Leisk
    42,355
    It may be closing the barn door after the horses have bolted, but always a good idea to do an EGR cleaning. Still, I would definitely consider a leak-down test, to see what's happening with the head gasket. Maybe also a block tester, which checks for exhaust gas in coolant. Anyway, regarding EGR:
    I found draining two quarts of coolant (from the radiator drain), into a clean container, I was able to subsequently remove the cooler without spilling a drop: the level of coolant is below the EGR system. There's just a few tablespoons of coolant at the lower back corner of the cooler: lift it out without tipping, and pour it into the previous coolant collected. After everything's back together, pour the coolant into the reservoir. It'll be a little high, but in my experience was back to normal with a day or two driving. I also left the coolant vent open while adding coolant (only possible 2010/11 model years), and squeezed hoses a bit.
    I found Oxi-Clean soaks slow but effective for completely cleaning the cooler, and also ran a thin wire through to aid with circulation. I've not tried it, but @Raytheeagle swears by pressure washer for this.
    You can also use Oxi on the intake manifold, something that's really part of the EGR circuit, and should be cleaned as well. While you're doing the intake manifold, clean the throttle body too. There's no need to disconnect it's coolant hoses: just unbolt and lift off the throttle body, lift it up and out of the way.
    The EGR valve is mostly aluminum, so I would not use Oxi on it, just carb or brake cleaner. It's relatively easy to clean. I tried but wasn't able to break loose the screws on the black cap. Maybe for the best: it's relatively easy to clean; I was able to gently pry up the valve and clean around anyway.
    You for sure want to remove the wipers and cowl, and it's good to have the car up slightly on ramps or safety stands, and the undercover removed.
    Some boiler plate info:
    The simplest way to see where you're at, is to check the degree of carbon build up in the EGR pipe, a stainless steel connecting pipe between the EGR valve and intake manifold. Watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Two or three other videos linked there too, for the full cleaning of the intake manifold, full EGR clean, and Oil Catch Can install.
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Some tools worth having:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
    See the attachments for all the relevant torque values, more info.
    #11 Mendel Leisk, Oct 5, 2019
  12. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Go for the pressure washer ;).
    With a pressure washer, you are in and out in 10-15 minutes :).
    The setup and disassembly are the longest bits of the job:cool:.
    And you get the cooler spotless in the process(y).
    mjoo likes this.
  13. Raphael Muscarelle
    661
    222
    Ok I just started it up after hours.
    First I noticed coolant somewhat low with some pressure in it.
    Startup took twice as long. Smoke came out kinda seemed white.
    Damn head gasket probably?
  14. Raphael Muscarelle
    661
    222
  15. Raphael Muscarelle
    661
    222
  16. bisco
    52,863
  17. Raphael Muscarelle
    661
    222
  18. bisco
    52,863
    some have found it more cost effective to put in a low mile engine
  19. Mendel Leisk
    42,355
    Leak-down test first, see what's leaking into what, if anything?
    Boroscope check of the cylinders for coolant is something else you could do.
    It's common for there to be oil below the throttle body. There'll be a pool if you don't have an oil catch can, say at least 1/8". With and OCC it'll be "oily", nothing more. I suspect some oil spits out of the intake ports
  20. Raphael Muscarelle
    661
    222
    I can hear the blowbye in crank case.
    But it really oil catch that seems like putting off inevitable for a month maybe. I drive 200 to 300 miles a day on highway that has no exits for 30 miles
