2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Yeah I'm surprised too but I can't really confirm if threads were leaking or not. I can say now it isn't leaking there now
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Do you have a picture?
    iPhone ? Pro
  3. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    What was leaking???? Valve cover?
  4. Raphael Muscarelle
    661
    222
    I don't think the valve cover is. I have yet to look up top with the UV in it. It looks like it where the head gasket is behind timing cover. I didn't put extra silicone on the joint when I fixed timing. So the timing cover probably has to come off.
  5. Raphael Muscarelle
    661
    222
    Really hard to capture. It's probably leaking all down the silicone really need the UV to see this type of leak.. IMG_20191101_163118.jpeg
    mjoo likes this.
  6. ASRDogman
    8,067
    4,089
    mm All I see is the blacklight. :)
    Oil leaks can be a pain. Doesn't make it easier when you can't get in to see things.
  7. Raphael Muscarelle
    661
    222
    Hard to get good photo of UV. It actually starts above that. I'm planning on resealing timing cover next week. 1853981944.jpeg
  8. ASRDogman
    8,067
    4,089
    I'll take your word for it. :) It looked like a lot of permatex to me. But at least you know where it's
    leaking from and can fix it.
  9. Raphael Muscarelle
    661
    222
  10. The Critic
    3,193
    2,333
    CA
    Did you follow the pattern in the FSM and squeeze your bead of silicone on the inside portion of the holes?
    iPhone ? Pro
    SFO likes this.
  11. Mendel Leisk
    42,355
    Here's the instruction. I think for DIY, with the engine remaining in the car, you will only do the application at the engine split line directly on the engine, the rest you would apply on the cover?
    SFO likes this.
  12. ASRDogman
    8,067
    4,089
    Phone camera's suck! They are better than nothing, but that's about it.
  13. Raphael Muscarelle
    661
    222
    Ok took off timing cover and started cleaning RTV off and right where it looked like it was leaking the RTV just wiped right off. Yeah that's confirmation that RTV was doing nothing.
    I had ordered mahle jv5188 timing gasket set. I'm very impressed with the RTV they use. It's thicker, stickier, and seems to dry faster then permatex ultra grey.
    SFO likes this.
  14. Mendel Leisk
    42,355
    Maybe ask for this stuff at a dealership parts department:
    Toyota Genuine Seal Packing Black, Three Bond 1207B
  15. The Critic
    3,193
    2,333
    CA
    Sounds like your surface was not prepped correctly. RTV never wipes off in the manner described.
    iPhone ? Pro
    Raytheeagle likes this.
  16. Mendel Leisk
    42,355
    Permatex Ultra-Grey is recommended as an alternative, here:
    Three Bond 1207 B sealant alternatives?
    I think Permatex recommends to use fresh tubes too, after it's been opened and sitting around for a few years, it's not that good?
    Ah woops, that's what you used??
  17. Raphael Muscarelle
    661
    222
    Yeah I did use new ultra grey.
    Not impressed with ultra grey.
  18. Raphael Muscarelle
    661
    222
  19. ASRDogman
    8,067
    4,089
    mmm The right tool for the job.. imagine that! :)
    Well, you learned something, and since you've removed the timing cover in and out of the car,
    you have experience with both now! :)
    And like "thecritic" stated, the surface probably had a little oil or grease on it, that's why it didn't stick.
    But, now you know, and you'll repair it and it won't leak...
    #199 ASRDogman, Nov 7, 2019
  20. Mendel Leisk
    42,355
    Acetone the best bet for cleaning?
