2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Carb cleaner
  2. Raphael Muscarelle
    661
    222
    I'm not removing finger nail polish.
    Mendel Leisk and ASRDogman like this.
  3. Mendel Leisk
    42,355
    Straight acetone will just about remove your fingers, lol.
    mjoo likes this.
  4. Mendel Leisk
    42,355
  5. Raphael Muscarelle
    661
    222
  6. Raphael Muscarelle
    661
    222
    IDK nail polish remover is 90% acetone.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The 10% that’s not acetone is keeping your fingers intact.
  8. Mendel Leisk
    42,355
    I've got a can of straight acetone, was using it to take off wheel weight adhesive, found it was starting to burn. This was after it'd melted off the finger tips of my gloves. :eek:
    Funny thing, there's a plastic "safety" cap, over top of the regular metal cap. My 2 cents: that thing makes it virtually impossible to open, and much more likely to spill in the process. I spent about 10 minutes ripping it off.
  9. Raphael Muscarelle
    661
    222
    Well happy to report all issues fixed and car has been in service for a few days. Everyday mpg has gone up. I'm sure it's due to rings breaking into the cylinders.
    PreRebuild I was getting 42.9mpg at 70mph. Today I got 48.6 on same road at same speeds. Nice
    mikey_t, Mendel Leisk, RMB and 2 others like this.
  10. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    YIPEE KIYAY! I am very happy for you! I'm sure it's nice and smooth too.
    I'm sure it was worth all the work, time, and effort.
  11. Raphael Muscarelle
    661
    222
    I hope so I need to drive it for 2 to 3 or maybe 4 more years. To make it all worth it. I use it for Uber.
  12. Raphael Muscarelle
    661
    222
    Update 3,500 miles later so far so good. I guess since nothing is makeing any strange noises from engine I did it correctly and good to go.
  13. ASRDogman
    8,067
    4,089
    That's good to know. I would think you'd know by now if there was a problem.
    Has the fuel mileage improved?
  14. Raphael Muscarelle
    661
    222
    Seems to have leveled off at 50 mpg combined 1/2 highway 1/2 street
    ASRDogman likes this.
  15. Raphael Muscarelle
    661
    222
    50 was what CONS said. Actual is 44.6 when con says 49.8
    Not sure why computer is wrong
  16. Mendel Leisk
    42,355
    I'm pretty sure the computer knows the actual mpg, or very close, and that Toyota management just demanded a little "tweak", before it's shown in the dash. :rolleyes:
  17. Raphael Muscarelle
    661
    222
    I have been wondering about accuracy. The milage vers cons never seemed correct. But never did manual calculation like I did today.
    That being said it would seem to me pre rebuild I was empty at around 370ish miles now empty at 447 miles. So good measurable difference.
  18. Raphael Muscarelle
    661
    222
  19. Mendel Leisk
    42,355
    The variation is at least reliable: you can look at what's displayed, factor in the fudge, and be pretty close.
  20. ASRDogman
    8,067
    4,089
    What it displays is NOT what reality is. It give you an estimate. Mine has only been within a 1mpg once.
    And I think it was only because I had only driven about 100 miles and wanted a full tank before driving all day.
    It's usually about 3.5 miles off, on average.
