2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Anyone have torque specs on engine rebuild related bolts
  2. Raphael Muscarelle
    661
    222
    More background on this becouse I just was reminded that I toped off the oil just before the symptoms started. So I'm figuring the ring blow by is forcing oil into throttle body then getting pulled into pistons causing misfire at startup untill the oil is cleared.
    So fix would then be ring job and mide as well pop new in bearings and maybe new timing chain. Maybe lap the valves as long as head is off. Along with makeing all things clean on way back together.
    Woohoo haven't done a rebuild in years.
  3. Raphael Muscarelle
    661
    222
    I'll turn the wrench myself.
  4. Inspector858
    Inspector858 New Member
    San Diego
    Unfortunate for these cars. The days of Toyota reliability vs corporate dollars are what surely brought Toyota to BMW. Goid luck with the rebuild. My 2011 started knocking then dealer said HG. Coolant in cyc 1 and 2. What a shame.
    Tim Jones likes this.
  5. bisco
    52,804
    all the best!(y)
  6. Mendel Leisk
    42,300
    Again, it's pretty much the norm, though hardly good, to see a bit of a swamp below the throttle body, unless you have an Oil Catch Can installed.
    The Toyota Technical Service Bulletins for excessive oil consumption, have some info on piston/ring rebuild:
  7. Raphael Muscarelle
    661
    222
    Hardly good indeed.
    I do know someone who is useing 1 qt every 1k miles due to rings.
    I'm still not sure what's wrong but going ahead with ring job.
    Will be cleaning EGR and installing new injectors and ignition coils.
  8. Mendel Leisk
    42,300
    If you feel up to it, sart a thread if/when you do.
    SFO likes this.
  9. ASRDogman
    ASRDogman Senior Member
    8,053
    4,083
    That's the best way to do it. :) Works for me!
  10. Raphael Muscarelle
    661
    222
    Thanks for PDFs.
    I briefly looked through them and I was planning on doing all that.
  11. Raphael Muscarelle
    661
    222
    Looking through these it seems that wear on wrist pinbushing might be cause of ring failure.
    I can't seem to find anyone with new wrist pin retainers
    mjoo likes this.
  12. Raphael Muscarelle
    661
    222
  13. Mendel Leisk
    42,300
    Yeah too I think 60K miles is the cut-off for that TSB?
  14. Raphael Muscarelle
    661
    222
    Ok thoroughly confused on what tools needed to take crankshaft main caps and connecting rods off.
    Document says SST 09205-16011 ah yeah put that in Google you get images of a socket yeah cool go to site it's male 12pt torx.
    I know my head bolts are recessed torx.
    #34 Raphael Muscarelle, Oct 7, 2019
  15. Mendel Leisk
    42,300
  16. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    How does damage to a wrist pin bushing cause damage to the rings? Does the piston get stuck at a bad angle? There are oil sprayers throwing oil on the bottoms of the piston - wouldn't that prevent a wrist pin seizure?
    Pixel XL ?
  17. Raphael Muscarelle
    661
    222
    The wrist pin keeps the Piston from improper twisting during combustion. Improper twisting puts improper pressure onto the rings leading to ring and possible cylinder wear. Thus increased blowbye and oil leakage past the oil rings which then makes the compression rings even less efficient.
    Tim Jones and mjoo like this.
  18. Raphael Muscarelle
    661
    222
    In the fix they replace the Piston. I would assume it has at least a slightly different shape more conducive to put even pressure on the wrist pin and bushing.
    mjoo likes this.
  19. Raphael Muscarelle
    661
    222
    See what I mean here is images of top of head bolt and another of the connecting rods on his rebuild. One is male one is female. Screenshot_20191007-113103__01.jpeg Screenshot_20191007-113121__01.jpeg
  20. Raphael Muscarelle
    661
    222
    I'm gonna go with 12 point 12mm female socket. Most likely will be correct. I did send the other post asking. Screenshot_20191007-121530.jpeg
