2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Gee I hope I don't find connecting rods looking like this Screenshot_20191007-113121.jpeg
    Mendel Leisk and SFO like this.
    52,863
    me too!:eek:
  3. Raphael Muscarelle
    661
    222
    Probably is tho. because can't compress coolant.
  4. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    You can straighten that out! :)
  5. Raphael Muscarelle
    661
    222
    Not advisable. Rod would be weekend next thing you know it will go through the block.
    Robert Holt likes this.
  6. ASRDogman
    8,067
    4,089
    I was joking....
    It can be straightened though. You'll need a press. Then will have to heat it up,
    and cool it off in a precess to restrengthen the allow.
    NOT worth it because it's cheaper to buy a new/used one.
  7. Raphael Muscarelle
    661
    222
    Finally got it out and can you say carbon build up.
    I'm glad I have new injectors. IMG_20191016_122756.jpeg IMG_20191016_190713.jpeg IMG_20191016_190743.jpeg
    Mendel Leisk and bisco like this.
  8. Raphael Muscarelle
    661
    222
    Slight rattle noise in input dampener. Might get new one darn they are expensive.
  9. Raphael Muscarelle
    661
    222
    Noise is nothing will talk about that in a different thread
  10. Raphael Muscarelle
    661
    222
  11. ASRDogman
    8,067
    4,089
  12. Raphael Muscarelle
    661
    222
    Rings jammed up but all looks good so far. Still have to measure head flatness 1571331897663.jpeg
  13. Mendel Leisk
    42,355
    The condition of the injectors and intake ports speaks volumes. This engine NEEDS an oil catch can, as early as possible.
    Tim Jones likes this.
  14. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    Thanks for the nice pictures.
    What I didn't know, they only have variable valve timing on the inlet side.
  15. Raphael Muscarelle
    661
    222
    Injectors are cruddy.
  16. Raphael Muscarelle
    661
    222
    I'm gonna say this. Every head bolt needed different torque to break free. This supports my theory that the head bolts are streaching. So when the war between combustion vs head gasket reaches a point where the headboard are long enough to give opening to combustion. Combustion makes a break for it into nearest opening
  17. Raphael Muscarelle
    661
    222
    Mendel Leisk, Robert Holt and mjoo like this.
  18. Raphael Muscarelle
    661
    222
    CR94 likes this.
  19. Raphael Muscarelle
    661
    222
  20. ASRDogman
    8,067
    4,089
    Oven cleaner and pressure washer time! :)
    Synthetic oil keeps things looking new.
