2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
  2. Raphael Muscarelle
    661
    222
  3. Raphael Muscarelle
    661
    222
    Robert Holt and mikey_t like this.
  4. Mendel Leisk
    42,355
    The Critic likes this.
  5. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
  6. Raphael Muscarelle
    661
    222
    To lap or not to lap valves that's no question. Take the time to lap.
    Yup I'm doing it in my bath tub.
    Brought some of job inside next day or so gonna be rainy. IMG_20191018_154954.jpeg IMG_20191018_155357.jpeg IMG_20191018_154954__01.jpeg IMG_20191018_155357__01.jpeg
    Robert Holt likes this.
  7. Raphael Muscarelle
    661
    222
    Lapping also fixes the seat.
    They sell lapping tool but I think that's a scam.
    DRILL on valve stem makes all the difference. Just have to support the drills weight as to not allow weight to affect stem.
  8. Mendel Leisk
    42,355
    Never done anything like this. Watched this video a while back, seemed a knowledgeable guy. Opinions?
    Note "squeak" at 12:50. Sound plays a big part; it's almost a "sonar" thing.
  9. Raphael Muscarelle
    661
    222
    That's the tool alright. Always used a drill
    Gonna send it for another spin
    mikey_t and Mendel Leisk like this.
  10. Raphael Muscarelle
    661
    222
    Well there are alot of things one can do to valves. This is no race car so port and polish is not needed. Just reseat is good enough.
  11. Raphael Muscarelle
    661
    222
    Due to the conditions in the engine the face of the valve as well as the seat in the head get pitted and dirty. This lowers the ability to contain the combustion, intake, and exhaust.
    Reseating the valve improves the containment.
    Robert Holt, mikey_t and Mendel Leisk like this.
  12. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    Thanks for all of the photos and updates. Really interesting to see. Also makes me think I should have run BG EPR for longer than fiften minutes before my oil change last week. Next time I think I'll do twenty to thirty.
  13. Mendel Leisk
    42,355
    Get one of those cellphone boroscopes, have a look through the spark plug holes.
  14. Raphael Muscarelle
    661
    222
    I just started watching this. Having super clean valves is not necessary. Using grinder so close to valve sealing surface could damage it beyond repair if there is a slip don't care how soft the brush is. Only surfaces that need to be perfect bar the slide part of the stem and the sealing part.
    I do remember they talked extensively in automotive school about the 3 different parts of the sealing areas of the valve but don't remember details. I would never put any kind of spinning cleaning brush to top portion of a valve for fear of irrevocably damaging the sealing surface. IMG_20191018_163927__01.jpeg
    Robert Holt and Mendel Leisk like this.
  15. Mendel Leisk
    42,355
    He is using brass bristles, but I'll defer to your verdict.
  16. Raphael Muscarelle
    661
    222
    If you look close you actually can see the 3 different surfaces in the valve sealing surface.
    No need to get valve any cleaner it will just get this dirty 20 miles down the road.
  17. Raphael Muscarelle
    661
    222
    I wouldn't even use nylon.
  18. Raphael Muscarelle
    661
    222
    Oh sorry I read wrong strike that.
  19. Raphael Muscarelle
    661
    222
    I would only use hand Held brass brush.
  20. Raphael Muscarelle
    661
    222
    But to achieve this I spin valve with drill in the head useing valve grinding compound. Using very light pressure up against valve seat resurfacing both seat and valve at same time.
    There are fancy machines that will do better job but I'm inclined to not spend that kind of money when this has worked great in the past.
    Again not a racing car with super high compression that needs such precision.
