2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Yup it's back together and runs inside car.
    Looks like timing issues tho. Gonna look at it tomorrow.
  2. Raphael Muscarelle
    661
    222
    Getting this code. Gonna look at what's the problem tomorrow. IMG_20191025_155535.jpeg
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Did you make sure the chain tensioner unlocked before you started the engine?
    iPhone ? Pro
    Raytheeagle likes this.
  4. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    That's great! Hope the timing issue is simple and quick to fix.
  5. Raphael Muscarelle
    661
    222
    Yes I did Twice with visual.
  6. Raphael Muscarelle
    661
    222
    Rebuilding an engine is really not that difficult just time consuming and painful for me.
  7. The Critic
    3,193
    2,333
    CA
    Do you have a picture of your timing marks after the engine was timed?
    iPhone ? Pro
  8. Raphael Muscarelle
    661
    222
    I'm fairly sure it will lead back to strange timing chain.
    I did out of car experiments before I put timing cover on and I had my doubts it was correct since timing mark was not on top dead center with timing chain on marks.
    The manual says to have it on top dead center in order to align the top marks
  9. Raphael Muscarelle
    661
    222
    Sure here is how I set it up. IMG_20191022_153050.jpeg IMG_20191022_153057.jpeg IMG_20191022_153103.jpeg
  10. Raphael Muscarelle
    661
    222
    If the dot on the wheel is the mark and not the gash it would make more sense
  11. Raphael Muscarelle
    661
    222
    Crank shaft is about 15 after mark of 0. I could take off harmonic balancer and the yellow would probably be on the dot.
    But that's not how manual says to check it. It says to put harmonic balancer on zero. Then check chain on top IMG_20191026_085046__01__01.jpeg IMG_20191026_085009.jpeg
  12. Raphael Muscarelle
    661
    222
  13. Raphael Muscarelle
    661
    222
    Car ran great even with blown head gasket. I don't see how chain could have been stretched this far and car still run as well as it did
  14. ASRDogman
    8,067
    4,089
    From looking at the photos, and drawing(#3), it looks like you are 1 tooth off on the right camshaft.
    It's hard to tell because of the angle, but it the right hand of the two red/brass links supposed to
    line up with the line? Or should the two split the line?
    Did you take photos before you took it apart? That's what I do, and/or make a video so I can put it
    back the same way. Unless of course it was messed before. But if it was working before you did the head
    gasket, it would have to be the timing chain, correct?
    Did you rotate the engine a few times by hand until the marks lined up again?
  15. Raphael Muscarelle
    661
    222
    Kinda sorta will explain
  16. Raphael Muscarelle
    661
    222
    Ok better instructions for timing is
    Make crankshaft at TDC. By either having cover on and harmonic balancer pointed to 0.:
    Or the keyway pointed twords the center bolt holes of cover.
    Then set up colored links on the marks.
    All this degrees crap makes it confusing.
  17. ASRDogman
    8,067
    4,089
    Degrees shouldn't matter. TDC is TDC.
    The photos/diagrams are confusing because the are blurry so it's hard to tell where the links
    line up, the right/forward link, or between them.
    That's why I take photos before taking it apart. They I compare the photos. :)
  18. Raphael Muscarelle
    661
    222
  19. Raphael Muscarelle
    661
    222
    I didn't image when I took it apart but the crank was 1 tooth off.
    So here it is now. With crank definitely on 0. IMG_20191026_170652.jpeg IMG_20191026_171603.jpeg
  20. Raphael Muscarelle
    661
    222
