2011 Prius startup noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Raphael Muscarelle, Oct 5, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    My engine ran great even with blown head gasket.
    Only symptoms we're it was getting hydrolock when it was stoped for more then a couple of minutes.
    I caught it before it ran out of coolant so it never overheated.
    Moral is: don't let it go because things don't fix themselves.
    ASRDogman and Mendel Leisk like this.
  2. Raphael Muscarelle
    661
    222
    Can't see timing in that.
  3. Raphael Muscarelle
    661
    222
    But I got more then age against me.
    In my lower back
    I have generated facets, stenosis, and atrophied muscles surrounded by the L4 L5 and sacrum. Since it all was naturally fused from birth. Unfortunately it all isn't fused anymore.
  4. Raphael Muscarelle
    661
    222
    Oh those images were in disassembly.
    During my timing fix I experimented and turned crank 4 times and chain advanced 3 or so links. Turned it 4 more times advanced again. Yet 4 more turns and advance again.
    When I took it apart for timing fix it was amazingly on the marks at TDC. But crank off 1 tooth.
    #164 Raphael Muscarelle, Oct 28, 2019
  5. Mendel Leisk
    42,299
    Maybe we're prone to let things slide, because organic things, say our bodes, can sometimes fix themselves, heal. But mechanical, not so much...
  6. ASRDogman
    ASRDogman Senior Member
    8,053
    4,083
    I'm 92, back has always been messed up, joints, eyes, ears, heart, etc.....
    Should have listened to my Dad, he said "don't get old". Too late...
    Robert Holt, bisco and Mendel Leisk like this.
  7. Raphael Muscarelle
    661
    222
    92 wow I hope I don't see that.
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    @bisco once said; "...expect issues to start cropping up, you had a good run." (y)
    bisco and Raytheeagle like this.
  9. Raphael Muscarelle
    661
    222
    Yup they to for instance have more oil pressure now have leak.
    In the area of Oil pressure sensor it was wet when I took it apart but no dripping yet. I replaced pressure sensor but now I have drip. Spent all day trying to track drip down. Gonna try to reseal pressure sensor tomorrow. If that don't work I might try UV dye.
  10. Raphael Muscarelle
    661
    222
    God couldn't make anything unbreakable neither can humans.
  11. douglasjre
    douglasjre Senior Member
    2,247
    751
    Null, NL
    thank you I was wondering why I was seeing what I was seeing. As an offshoot I'd really like to learn something from this. It sounds like you were successfully able and not collide the pistons with the valves. This would mean to me that they are not interference valves. Is this correct?
  12. douglasjre
    2,247
    751
    Null, NL
    FYI me and my friends have a total of 16 Priuses 14 of which are 3rd gen. We have just done our second head gasket. as a test to see if the bolts were loose I tried tighting them first and found they were all about 170 foot pounds. I consider this sufficient evidence to say looseh bolts are not the cause of a leaking head gasket.
    Robert Holt and SFO like this.
  13. Raphael Muscarelle
    661
    222
    It is an interference engine.
    When I was testing I did learn the intake valves will hit the heads.
    This was a problem with belt driven timing. The teeth would strip off the belt after so long of use. These engines would need timing belt replaced fairly often. Somewhere there is a list of which engines. We were given a list of them in auto school oh so many years ago.
    Unless there is a catastrophic break in chain or severe timing misalignment during install we are good.
    douglasjre likes this.
  14. Raphael Muscarelle
    661
    222
    Ok
  15. Raphael Muscarelle
    661
    222
    Ok hope leak is fixed.
    Now that was rookie blunder. I got almost a turn our of the oil sensor.
    #175 Raphael Muscarelle, Oct 30, 2019
  16. Raphael Muscarelle
    661
    222
    Arrg used UV dye still looks like leaking from oil sensor despite ultra blue silicone. Took sensor out cleaned off and used locktiite 242 waiting on dry time.
    I can see how locktiite might work over silicone becouse of how thin it is. When I took out sensor the silicone seemed to stay on outer threads where locktiite should permeate through all the threads
    Robert Holt likes this.
  17. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The oil pressure switch is sealed using thread sealant. Loctite is only used to seal threads to prevent the object from backing out; it is not used to seal for the purpose of preventing leaks.
    iPhone ? Pro
    Mendel Leisk, mjoo and Raytheeagle like this.
  18. Raphael Muscarelle
    661
    222
    Not according to the manual
    Note attached pdfs
    I think I sent correct ones View attachment 0_Toyota Adhesive & Sealant Cross Ref.pdf View attachment 2010 Toyota Prius Repair Manual - oil pressure switch install.pdf
    mjoo likes this.
  19. The Critic
    3,193
    2,333
    CA
    That is strange. Every oil pressure switch I have ever installed has been with thread sealant. Never had any leaks either.
    The one on my Prius had been sleeping. When I did the head gasket I resealed with thread sealant. No leaks or seeps in over 14k miles.
    iPhone ? Pro
  20. Raphael Muscarelle
    661
    222
    If oil switch was leaking it isn't now.
    But I see the timing cover looks like it's leaking near head gasket
