2011 Prius Sunroof Deflector Seal Deterioration?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daliss, Jan 19, 2017.
  1. Tideland Prius
    16,559
    I wonder what kind of combination will lead to it. When I sold my 2010 at 10 years olds, the moonroof was working properly and the seals look ok (worn but not cracked or peeling away). I use my moonroof regularly as I love the open top feeling on cool days (and in the summer).
  2. orenji
    orenji Senior Member
    5,887
    3,488
    It appears this is a cold climate issue. Not much of a concern for warmer areas such as LA.
  3. mikes951
    mikes951 Junior Member
    46
    US
    Does any aftermarket company sell just the rubber trim around moonroof?
  4. Francine2010
    Francine2010 New Member
    Montréal, Canada
    Technology
    Joining your group. I have a 2010 Prius and the deflector rubber began deteriorating in 2013. I reported twice to my dealer in Montreal and finally got it replaced in 2015 with repair cost shared between dealer and me.
    The problem has now returned with both glass components of sunroof. The rubber trimming is bubbling under and around, and is detaching itself from the glass rim. It seems stretched out and dried out. Gluing it back in place definitely not possible. It looks very bad.
  5. Canard
    Canard Member
    223
    Ontario, Canada
    We purchased our Gen3 in 2010. A year later the rubber around the sunroof had deteriorated significantly; 9 years on it's absolutely terrible and embarrassing. Somewhat relieved to figure out it's cosmetic only, but disappointed they could let something like this happen and refuse corrective action.
    It's so obvious it's a flaw in the material, too - the right side of the car is perfect, it's the left side only that starts in a very specific position where the deterioration is. Yes I live in Canada (60 C degree swing from summer to winter), and no I don't use any exotic cleaning products.
    Strudel and Mendel Leisk like this.
  6. Suz Knob
    Suz Knob New Member
    i have a 2011 Prius, and live in Buffalo, NY. Dec 2019, after our 1st snowfall, the seal failed on my deflector panel also. part # 63201-47010. upon closer inspection the two corners were also cracked. my dealer wanted more than $1200 to repair. i went thru my car insurance (full glass coverage) and had it replaced FOC. interestingly enough, the actual part was sold to safelight for approx $400, but my dealer was charging me $1100. attached is pic of seal failure.
  7. Mendel Leisk
    41,473
    Toyota should fess up! :mad:
  8. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Everyone should go complain to them first then get it repaired so at least their foot will be held to the fire. If no formal complains, how will they even know it’s an issue?
    In that note, if anything like that happens to my car, I’ll let them know how I feel with a certified mailed letter to Toyota.
    #88 Grit, Jan 5, 2020
  9. Strudel
    Strudel New Member
    Chambly, Qc
    Technology
    I have the same issue with my Prius 2012, in Montérégie (south of Montréal). No later than this week, my Toyota dealer (St-Hubert Toyota) estimated the cost of repair, parts and labour, to 970$+tx, to change the whole deflector only. If your Québec city is asking almost 2400$ for the same thing, I would seriously question their integrity...
  10. Bill Aver
    Bill Aver Junior Member
    My 2012 did the same thing. Both deflector panel and sunroof. Toyota wouldn’t cover anything at all.
  11. Kootenay
    Kootenay New Member
    BC
    Interesting thread, my seals were all replaced a few years ago on my moonroof. After much discussion my local dealer, Toyota Canada and I all paid a third each of the $2500 or so final bill. Now they're completely disintegrated again. I'm looking for best solution to not look like crap without the ridiculous price tag. Pretty sure Toyota won't be chipping in this time. 6 year old car, only been hosed off, lives outside in BC. My kids drive a 15 year old Mazda that has a sunroof with no seal issues, same climate. What the hell
    Mendel Leisk and Grit like this.
  12. ChiroLisa
    ChiroLisa New Member
    Brookline, MA
    My 2012 Prius III has exactly the same problem! I have been quoted $600 to fix it as the gasket/liner itself cannot be purchased separately. Seems people have had varying degrees of success with getting Toyota to cover this. Any hints?
  13. Kimura
    Kimura New Member
    Norway
    Screenshot_20200128-143010.png DSC_1348.JPG DSC_1350.JPG I have this leak in my car every time it rains. See picture. Is it a sunroof leak or windshield leak?
    Toyota wants 2000$ to fix it and they say it's the sunroof. The sunroof rubber is detoriated and causing the leak (see pic).
    They say I have to change entire sun roo
  14. fuzzy1
    10,458
    Or is it an internal drain leak, or drain clog with overflow?
    I haven't yet read this whole thread, having been referred to it only recently. But my sunroof gasket failure has progressed to being much worse than yours. Yet mine doesn't (yet) leak, and in a quick skim thought numerous others were also not leaking.
    A previous car had a sunroof leak not from any seals, but from the plastic drain tubes down the A pillars shrinking, shortening, and pulling off the drain pan nipples, causing the drain water to spill on to the pillar trim. Other owners previously having the same leak issue identified a diagnosis I hadn't yet reached, and pointed to a cheap DIY solution: pull off the trim, pull and stretch the drain tubes back to where they belong, and secure to the nipples with hose clamps so they won't pull off again.
    A clogged drain or tube would require some cleaning or clearing, but not require a sunroof replacement.
    These possibilities might be worth checking before spending several kilobucks on sunroof replacement. Have any other Prius owners dug into this leak situation?
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    (n)
  16. fuzzy1
    10,458
    Searching more thoroughly for other leak reports in this thread, and the thread from which I was referred to here, I'm still missing them. Where did you find them?
    There are sunroof leak reports in other threads, use the Search feature across the whole site. But the first several I looked at were not accompanied by descriptions or photos of the types of gasket failures shown in these two threads.
  17. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Sounds like it would be a good idea for all you sunroof owners to get the add-on to your insurance that is $0 deductible for glass repairs (or for comprehensive if glass coverage isn't available separately). I unfortunately have gone through about 5 windshields in almost 8 years now, but didn't pay anything for them. I did have to pay for rust repair that occurred under the windshield adhesive, but that's another story.
  18. SylvieM
    SylvieM New Member
    Beloeil
    Premium w/ Solar Cells
    I have same problem with my Prius 2012 sunroof. Dried out seal. TOYOTA Canada only solution is to replace whole glass $2000. If the rubber is only cosmetic why isn’t there another fix to replace the rubber only.
    Has anyone try to remove the rubber completely?
    is anyone considering collective legal action? This is obviously a factory /design default.
    QUOTE="Daliss, post: 2490349, member: 99178"]I don't think it is likely to be that for a couple of reasons:
    1. The examples come from people living in quite different regions and jurisdictions, so not sure how likely that these jurisdictions all use the same road de-icers. Where I live it is mostly basic road salt.
    2. If it was due to a particular chemical substance, then it should affect the rubber on other parts of the car (It doesn't: I have rubber lining and seals quite close by that are in perfect shape) and it should also affect other Prius owners in my city, and in fact all other car owners; that does not seem to be the case; the damaged rubber is limited to the deflector and sun roof, thereby suggesting a manufacturing defect with that part. (I also have a 25-year-old Corolla station wagon and after all these winters, the rubber seals are still in pretty good shape!)
    [/QUOTE]
  19. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    You’ll get chuckled at from people here, even if you lawyered up. Seen the replies before.
  20. BStoll
    BStoll New Member
    Woodinville, Washington
    I stumbled in this looking on the web for a solution to my sunroof problem.. I have the exact same issue as you all. The seal around my 2011 Prius sunroof is buckled and twisted up. I went to the dealer looking for a solution and was told 2500.00 to replace sunroof, glass and all. I'm in Seattle, haven't opened it in months, and I don't get it. Has anyone figured out a reasonable solution for this problem?
