2011 Prius Sunroof Deflector Seal Deterioration?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daliss, Jan 19, 2017.
  1. ASRDogman
    ASRDogman Senior Member
    7,599
    3,916
    if you read every threat about this, then you know the only solution is to buy a new seal
    from Toyota, very expensive. Apparently, no 3rd party is making them, at least not that I know of.
    And no one has seemed to alert Prius Chat.
    You may have better luck in your search.
    Grit likes this.
  2. MarFar78
    MarFar78 New Member
    Washington, DC
    Some people on this thread decided not to replace it and just removed it. A couple people got Toyota or the dealership to eat some or all of the costs, while others tried non-Toyota replacement seals, according to all of the threads.
  3. Dzzzt
    Dzzzt Junior Member
    West Michigan
    My digest of this 9 page, multi-year, riddle discussion is that the rubber trim (not a seal!) strip's main function is to close down the gap enough to keep bits of junk out of the sunroof drains so the drains don't get plugged up, and most of the water out to avoid overwhelming said small drains.
    It is esthetic in that it keeps leaves, twigs, grass clippings, insects, dirt, ice, etc from collecting in the open gap and looking unsightly.
    The ESUPPORT 4M Z Shape Weather strip (posted by delta6014 post #136 on 9/20/22 of this thread) looks like it's worth a try. I'm going to ask about it at an auto parts store to see if it's a locally available item. There are quite a few online sources for it that apparently all use the manufacturer's pictures of it.
  4. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Any rubber in the bare sun or snow needs some type of chemical protection treatment all year round just like car paint if you want it to last. Every 6 months I give it a slather of aero grade coat protection, still no signs of deterioration. And yes the egr been cleaned with an oil catch can illegally installed since 2019 in the eyes if CA politicians.
  5. Randy Sampson
    Randy Sampson Junior Member
    Seattle, WA USA
    Let me know if it works. I’ve had this problem for quite a while and have never found a solution other than a $1500 sunroof replacement plus an installation cost.
  6. Markee
    Markee Member
    334
    South Florida Broward County
    In the end after having several auto glass techs come out that couldn't figure out why it was leaking and going to the dealer and getting quoted over 2k to fix it I found a local guy that was totally familiar with the issue come out pull the whole thing apart took hours and replace the inside seals and the rotted from strip good as new charged me around $600
  7. Mendel Leisk
    41,473
    Toyota dropped the ball on this, and isn’t owning up, their usual modus operandi.
    Grit likes this.
  8. Markee
    Markee Member
    334
    Toyota totally jerked me around on this. They said they had a customer loyalty program for people who consistently maintain their vehicles—said my record showed I was a good candidate since I basically did all my oil changes there. Said there were no guarantees but then said again they felt I was a good candidate the catch was I'd have to pay the dealer up front a couple hundred just to evaluate the vehicle I did, and they ended up denying the repair—and wouldn’t even return my calls.
    hill and Mendel Leisk like this.
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    This post reMinds me to quarterly slather uv protectant on all rubbwr seals on the sunroof assembly this weekend. Mine is open when weather is not raining at all times :cool:
