2011 Prius Transmission 395k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by Raphael Muscarelle, Oct 16, 2022.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Last week I had low flow in hybrid Coolant. Parked car waited for pump. Replaced pump and coolant with fresh.
    Today checked coolant reservoir was empty. No Sign of coolant leak outside so i Put coolant in. Wondering where it might have gone I opened fill for transmission I had fluid coming out. Have the car jacked up a bit higher then when I filled. I drained the transmission coolant. Smells funny and kinda black. Not sure how I can tell if there is water in it.
    If I have to replace transmission any tips would be appreciated.
    I've seen them in yards close to me for fair price.
    Here is a look at the oil.
    #1 Raphael Muscarelle, Oct 16, 2022
  2. Raphael Muscarelle
    661
    222
  3. Raphael Muscarelle
    661
    222
    How much transmission fluid came out about that much. Somewhere around a gallon. IMG20221016125538.jpeg
  4. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    If transmission had water intrusion the fluid would look like a strawberry milk shake. The fluid you showed looks like no water got in. However, when was the last time it was changed? Fluid looks burnt.
  5. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
  6. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    It gets dirty like that it's super high mileage I would say maybe your transmission might have been changed once you know while it was in warranty or something maybe maybe not so just change it and go on about your business It looks just like my Gen 2 fluid at bowl 230 some odd 1,000 240 ish mine was actually blacker than that didn't think anything of it just changed it and didn't use Toyota branded either used to think it's Castrol or somebody's multi CVT fluid that covers the Prius supposedly so it's been in now about 25,000 mi and it's still dark red so far as I'm concerned I'm good to go it's not a pressure fluid it's not a pressure transmission or like a regular automatic so should be okay
    2010moneypit? likes this.
  7. Raphael Muscarelle
    661
    222
    Maybe all transfluid wondering how likely if missing coolant is in there as well.
  8. Raphael Muscarelle
    661
    222
    I got fluid coming. I Have a few days so I have my grid charger going. Hoping to condition hv battery
  9. Raphael Muscarelle
    661
    222
    170k ago. Smells burnt.
