2011 Prius V Check hybrid system Light on
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Fierofly, Mar 9, 2020.
  1. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    My Prius will run normal for about 5mi, you can see the energy going back and forth from bat to motor on the screen, then the power mode will turn off and you can't select any other mode, no energy lights going back and forth between bat and motor, cruise won't work. Engine runs fine and it looks like it's running on gas engine only. If you turn off car it'll do the same again
