2011 Prius Won't Start - New Battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Wasatchprius, Dec 4, 2016.
  1. Wasatchprius
    Wasatchprius New Member
    Utah
    Earlier this week, I went to start my car and when I pushed the start button, the lights on the dash flickered and only the check engine stayed on. I used another vehicle to jump the Prius and then promptly took it to the Toyota dealer to replace the 12v battery. I replaced the vehicle and for a couple of days, the car started flawlessly. This morning, on a cold day, I once again went to start the car and the lights on the dash flickered and the car would not start. The electric windows and locks do not even operate.
    Did I get a bad battery? What else could be causing the car to not start?
    Thanks!
  2. mrbigh
    3,686
    699
    Long Island, NY
    you could have a defective Hybrid system INVERTER no recharging the " 12VDC" circuits or some one accidentally is leaving an unclosed door or a dome light while the vehicle is unattended.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    When the battery was replaced the new one should have been fully charged with an external charger.
    The charging voltage also should have been checked.
    NOT doing either (or both) of those things could have caused your problem.
    The both need to be done now.
    52,877
    you bought a new battery, it's their responsibility. maybe a loose connection.
