2011 Toyota Prius - car will only go into Neutral
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by amyjoelle, Oct 19, 2024.
  1. amyjoelle
    amyjoelle Junior Member
    Oxnatd ,CA. 93033
    When I push start, the car will only go into neutral . The message on the dash reads, “ Check hybrid system “. What do I do?
  2. Brian1954
    Brian1954 Senior Member
    2,670
    1,068
    South Central PA, USA
    You need a scan tool that is capable of reading all the trouble codes in your Prius. Read the first post in the linked thread and then skip down to post # 37: https://priuschat.com/index.php?posts/3246758
    I am guessing that you have a P0AA6 trouble code.
    #2 Brian1954, Oct 29, 2024
  3. Tideland Prius
    16,678
    Updated title to be more informative.
    Brian1954 likes this.
