2011 V ( JDM ) 2011 Oil reducing
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ahmad ashfaq, Jan 15, 2019.
  1. mikefocke
    4,067
    1,855
    Sanford, NC
    The problem with burning oil is it get into the EGR, cat and O2 sensors. Ever cleaned the EGR?
    ahmad ashfaq and Mendel Leisk like this.
  2. ahmad ashfaq
    ahmad ashfaq Junior Member
    57
    islamabad islamabad
    2011 Prius Alpha
    Shall i Drain the Oil in Oil Can to ascertain the level ?
  3. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Yes O2 cleaned , but EGR will do today
  4. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Yes Sam , only 400 miles, and interstengly the decrease is more on highway then local driving .
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No surprise there.
    When an engine gets "loose" it uses more oil under increasing strain......like increased speed.
    ahmad ashfaq likes this.
  6. Mendel Leisk
    42,165
    I would just monitor carefully, noting the level and miles.
    The distance between the two marks is 1.5 inch, and represents 1.5 liters, or 1.6 quarts.
    To more easily read the dipstick: pull it out, then wait about 5 minutes before reinserting for the check. The tube the dipstick goes into tends to have oil smeared along it's length when you pull the dipstick out, which transfers to the dipstick if you do the insertion for the the check right away, making it difficult to discern the true level. Waiting that few minutes gives that oil in the tube time to drain back down.
    jzchen and ahmad ashfaq like this.
  7. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Thanks For the Tip Mendel.
  8. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Raytheeagle and Mendel Leisk like this.
  9. Mendel Leisk
    42,165
    Good you're getting your hands dirty. (y)
  10. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Lots of it , credit goes to our Petrol quality , which is the worse in third world i guess ,
  11. Mendel Leisk
    42,165
    Has Oil Catch Can been mentioned? Worthwhile to install, between PCV valve and intake manifold, to waylay most if not all of the airborne oil/water/gas droplets.
    Have you watched @NutzAboutBolts videos here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    From your pictures it looks like you have the full EGR off for cleaning?
    Is intake manifold done as well? Especially pay attention to the EGR passages.
    I'm thinking your car is roughly per North American Prius v? All the info should be applicable then.
  12. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Yes The intake manifold is cleaned as well , so has the PCV , and yes you are correct its almost the same Spec as North American v,
    Am watching the videos now , thanks for the link,
  13. Ralph skelley
    Ralph skelley Junior Member
    Nm
    You might change the pcv valve and clean the oil from intake and mag sensor.
    #33 Ralph skelley, Apr 18, 2019
  14. Mendel Leisk
    42,165
    probably mean MAP sensor (Manifold Absolute Pressure). And yeah, it's invariably oil-soaked. Not sure how much it matters, but doesn't seem good.
    Careful with that sensor, they're very expensive. MAF sensor cleaner is safest I think.
  15. mikefocke
    4,067
    1,855
    Sanford, NC
    Of is it MAF sensor. Mass airflow sensor. Used by the engine's computer to measure how much air so it can adjust the fuel flow for the ideal air/fuel mixture. Sits in the air intake path after the air cleaner.
  16. Mendel Leisk
    42,165
    Mor'n likely MAP, it's below throttle body, nearly in the "sump".
  17. dyun1dyun1
    dyun1dyun1 Member
    61
    40
    Severn, MD and Boone NC
    2017 Prius v wagon
    I didn’t take the comment as semantics but being more precise. My Volvo and other cars give me low oil warning message when I am below the safe level. Or what you are referring to as low oil.
    iPhone ?
