2011 with P0401 driving me crazy
Discussion in 'Gen 3 Prius Main Forum' started by Steelerfan2018, Aug 1, 2022.
Tags:
  1. Steelerfan2018
    103
    42
    Pittsburgh
    Hi all,
    2011 prius with 150k miles. A history of P0401 errors. Car also uses about a qt of oil between changes. Otherwise the car runs well.
    I now have something like $1500 spent in solving P0401. I have had the following done: new spark plugs, EGR cleaned, EGR cooler cleaned, PCV valve changed, MAP sensor cleaned. It has run a few months without errors, but it is now back again - the problem this time is that I am short on funds and it may be a while before I can have it worked on again.
    - if anyone out there has had this error, how long can you drive with it?
    - is there anything I can do to keep it running OK before I can put it in the shop?
    Thanks,
    Rob
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    Have you added an oil catch can yet? Perhaps adding that and cleaning EGR, the pipe and the cooler again will put this problem behind you for good?
    #2 PriusCamper, Aug 1, 2022
  3. nate358
    nate358 Junior Member
    94
    Columbus, OH
    Oil catch can does not go into the Egr system... It goes after the PCV valve before going back into the intake manifold.
    PriusCamper likes this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    Maybe the egr valve has failed shut. Other reasons such as a clogged egr cooler and a bad map sensor seem to be covered.
  5. PriusCamper
    13,465
    5,431
    Oops... Just edited that part. Thanks!
  6. ChapmanF
    19,025
    I didn't see any mention of the intake manifold being cleaned. Its four small EGR passages are part of the total EGR path, and any occlusion there can cause your EGR insufficient flow code just as easily as occlusion anyplace else.
    The manifold is easy to remove for cleaning.
    Mendel Leisk and PriusCamper like this.
  7. Steelerfan2018
    103
    42
    Pittsburgh
    Hi all, thanks for the replies.
    Q - I am thinking of trading it in on a 2013. Did they fix the oil burning issue by 2013?
    Thanks,
    Rob
  8. PriusCamper
    13,465
    5,431
  9. rjparker
    11,104
    6,967
    Texas Hill Country
    No almost exactly the same. In 2014 mid production they used better pistons and rings.
    Compare last six digits.
    Most likely your egr valve is no longer opening or you have a completely clogged intake as suggested above. If you want to go down the clean intake rabbit hole, here is a good video.
    His approach "apparently" cleared the morning stumble and mid range operation. Until you read the comments where he bit the bullet a few months later and rebuilt the engine because of oil burning and the resulting head gasket fail.
    Which is why most dealers and many pro mechanics rebuild rather than do a simple head gasket. Nevertheless, the video is clear and concise.
  10. KamiKKazi
    KamiKKazi Member
    92
    60
    OC
    If you can get a cheap pressure washer and pressure wash the intake it will clean out the EGR passage. Once you overcome this issue your car will run a lot better, I wouldn’t sell your car just because of this issue. You could even buy a new clean intake if your egr pipe and egr cooler are still clean that would fix your issue
  11. Steelerfan2018
    103
    42
    Pittsburgh
    Crazy update - the engine light went away on its own.
    I also looked up the value of my 2011 and it has gone up $2500 since I bought the car last year. Seriously thinking of trading it in while the value is this high.
    Thanks all,
    Rob
  12. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    It's a break even or less transaction on that valuation trading it in...the value of whatever you buy is also inflated....probably more than your prius. If that's what you wanted to do anyway, by all means do it, but if you think you're getting ahead on it...well....most likely not.
