2011Prius 98k miles and have not changed engine/inverter coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JB fan, May 9, 2023.
  1. JB fan
    JB fan Junior Member
    Orange County, CA
    But - I've been keeping up all the other maintenance up pretty well.
    Just getting around to it now and I'm not sure if I should put my trust in an independant or take it the dealer?
    Wondering if the Toyota products for such a service might be better. Thanks so much
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Just text it with text strips for coolant like you do a pool . See how bad it's not. Nice and pink etc? probably good to 150K . And can be dumped and changed in a few minutes at home .
  3. JB fan
    Orange County, CA
    Hello and thank you for your response, but oops, forgot to mention that I'm not mechanically inclined. So, my only choices are taking it to an independant or the dealer. Toyota 2011 Prius Warranty Maintenance Guide says to replace at 100k miles or 120 months.
  4. JC91006
    16,939
    8,647
    With the high labor rates in CA, I would just look for a coupon at a local dealership's website and have it done there. I don't think it's much cheaper at an independant shop in CA. It's best to have the right coolant put in vs going to an independant and them putting in the wrong stuff and saving you only $20. This is a once in 50k miles service, the $20 just not worth it
  5. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Personally I would not have this work done, but that’s just me
    Paladain55 and Tombukt2 like this.
  6. JC91006
    16,939
    8,647
    Unfortunately Toyota has a lifetime transaxle fluid, but not a lifetime coolant
  7. JohnPrius3005
    423
    235
    After reading numerous PriusChat tales of woe after simple service items, I stand by my opinion
    Only let someone you know and trust personally touch your car.
  8. JC91006
    16,939
    8,647
    Interesting reasoning. Have you read all the drownings that occur in CA and Hawaii? That hasn't stopped you from moving away from the coastal states. I know, what a crazy thing to say
  9. JohnPrius3005
    423
    235
    Touché
    I’m very careful where I swim
  10. Tombukt2
    13,875
    2,521
    Durham NC
    In Cali. You money's spread very thin All over issues that need attention. And yes I got out of the coastal areas a long time ago because after living all over the world I know how quickly that can become a real bad disaster so I live inland a little bit on purpose for my house my property things like that I can be at the coast in a few minutes if need be under an hour practically so there's no reason to have my house sitting and possible disastrous events taking place. Similar with my vehicle and a lot of the things that I own I don't let repair people touch almost anything I own I'll just generally repair it myself I can solder and weld and all that nonsense until my car went over to a buddy of mine to have the engine put in it I hadn't had anything serviced or touched by another human in probably 50 years No kidding. Other than my dry cleaning.
  11. Mendel Leisk
    42,369
    Just get it done.
    Toyota Canada says to do both the engine and inverter coolant at 160k kms (~100k miles) or 10 years, whichever comes first. Which I did in November of 2020, the 10 year mark, around 90k kms. I DIY’d them, was not that involved. Used Toyota Super Long Life.
    For engine coolant change through dealership, you shouldn’t need to pay more than $150 USD. The inverter coolant change (if-and-when you're getting it done) is simpler, say $125 USD.
    #11 Mendel Leisk, May 10, 2023
  12. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    I wouldn't be opposed telling someone to watch a youtube video on how to change the engine coolant. Its really just opening the petcock valve on the radiator and the resevoir lid and letting it drain out, and then refilling. Very simple procedure. Just remember these cars use pink coolant, not red. I see people throw in red all the time. So make sure to grab super long life coolant from Toyota.
  13. JC91006
    16,939
    8,647
    Technically you can use either pink or red. The only difference would be the service life of the fluid, the red being a non super long life coolant, has to be changed out every 30k miles.
    The OPs car has almost 100k miles and over 10 years old. Maybe it's time to just spend $1000 and do all the stuff that's coming up in the next 20k miles?
    1. Spark Plug change
    2. Coolant change (both loops)
    3. Clean EGR circuit
    4. Possibly change electric water pump when doing coolant
    5. Change all filters
    6. Change brake fluid
    Paladain55 and Mendel Leisk like this.
  14. Mendel Leisk
    42,369
    The red (Long Life Coolant) is also full-strength (if I’m not mistaken), likely cheaper thus (once you dilute to 50/50).
    Also, if you ever do a water flush, which will leave residual water, the full-strength will allow you to refill to 50/50. More thoughts on that in my signature (flushing out…).
  15. bisco
    52,891
    if i went to a dealer, could they hook up tech stream to see how clogged my egr is, or would they have to open it up?
