2012-17 Rear Spoiler
Discussion in 'Prius v Main Forum' started by Moriah Richardson, May 25, 2018.
  1. Moriah Richardson
    Moriah Richardson New Member
    Tampa, FL
    The rear spoiler on my 2012 Prius V five has just recently shown signs of sun damage. The paint on the rest of the (non-plastic) car is pristine. I've contacted Toyota Corporate for support, but unsurprisingly they will do bring since it's out of warranty. I'd appreciate any information regarding a used OEM replacement (it's navy), or tips to restore it. Thanks!
    #1 Moriah Richardson, May 25, 2018
  2. prevee5
    prevee5 Member
    122
    Monrovia, California
  3. prevee5
    prevee5 Member
    122
    Unfortunately, I do not have a specific contact at Toyota. However, I experienced the same issue with my 2012 silver Prius v a couple years ago. I was going to get it repainted as it was not restorable. But paint cost was too high for what it was worth.
    At the time, I just called the toll-free number from the “Contact Us” corporate web page. Spoke with someone there and explained the whole situation and was assigned a case number. Make sure you seek help from the dealer prior to calling as this is their normal protocol. Within a couple weeks they informed me I was approved a replacement spoiler and installation at my local dealer. Was surprisingly simple.
    Contact Us | Contact Toyota
    Good luck!
  4. orenji
    orenji Senior Member
    5,887
    3,490
    Was your V less then 5 years old at the time?
  5. prevee5
    prevee5 Member
    122
    Bought the car new 10/2012 and had the spoiler replaced some time in 2016. So yes, less than than 5 years.
  6. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    If I understand, you are the original owner purchased new year 2012.
    In year 2016, you replaced the spoiler.
    Why? Warranty, insurance claim, self damaged.
    Need more info and closer in person panel inspection.
    Typically these panels come unpainted and a body shop resprays the color.
    You can pursue OEM Toyota or dealer if a warranty.
    Refer to your warranty booklet for OEM length of time, replacement parts I believe typically only have a 1 yr warrant.
    Or the repair shop if a repaint which you or insurance paid for.
    Either of these may offer lifetime warranties.
    Or least expensive, if no coverage, try to color sand and buff the paint.
    I don't see any paint peeling so a polish may (may) work.
    Appears to be clouding of the clear coat, not the color.
    Or super inexpensive, paint only the top surface or even the entire spoiler flat black.
    Good luck.
  7. PriusV17
    PriusV17 Active Member
    440
    207
    CA
    2017 Prius v wagon
    Very interesting. A portion of the top spoiler looks pristine. Well looks like you can buy it pre-painted for about $300 from Toyota. I would check with your local dealer. They may give you a discount if you let them have the original. Or you can try to sell the original and to recoup some money back. Having it repainted at a body shop will also cost a few hundred.
    Dark Blue: 76085-47911-J0
    OEM Toyota Parts Online | Toyota Of Colorado Springs
    Spoiler for 2017 Toyota Prius V | cheap parts
