2012-2015 prius plus Back Door compatibility check
Discussion in 'Prius v Technical Discussion' started by johnpr, Jul 11, 2020.
  1. johnpr
    johnpr Junior Member
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    Hello there!
    We had a small accident with our prius plus 2012, while reversing into the garage, my wife didnt close the back door and bent the door.. mechanic managed to bend the door back into shape, but its only a temporary solution, we need a new door..
    I found one complete door for sale, but its from 4th gen prius plus..
    The question is, is there any change on the back door between 3th and 4th gen Prius Plus (V)?
    Thank you for your advice!
    52,905
    can't say positively, but since gen4 is a complete redesign, it's highly likely that they are not the same.
  3. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    To do this kind of research I'd go to http://www.car-part.com and search up the door for your year/model. It has a pretty good interchange as far as I'm aware. Might be able to find a replacement there in the proper color, (hopefully).
    Best of luck!
    moto g(7) power ?
  4. johnpr
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    I asked my toyota dealer, he checked the door and found that there were no modifications made onn the rear door of the prius V (plus) between 3rd and 4th generations, they should be the same..
    Iwill double check that info on http://www.car-part.com thank you for good advice!
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Ahh. You may not know this but this thread seems to be in the lowercase v (wagon) side of the forum. (Unless Tapatalk is being buggy like it has in the past)...
    moto g(7) power ?
    johnpr likes this.
  6. johnpr
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    What does it mean for me?
  7. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Good point. It doesn't really affect your results. Hope you find one in your color so no painting is needed.
    Best of luck!
    moto g(7) power ?
  8. mikefocke
    4,083
    1,865
    Sanford, NC
    The Prius v (note lower case) is a station wagon never issued in a Plus model. That is the forum thread you are posting in. Not liable to give you the answer you want.
  9. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    2012 prius plus back door - Google Shopping
    or you could go here look at the numbers and change the year... see if they are the same
    Genuine OEM Rear Door Parts for 2012 Toyota Prius V Five - Olathe Toyota Parts Center
