2012 3rd gen, RH headlight has no power.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by brian01234, Jan 30, 2019.
  1. brian01234
    brian01234 Junior Member
    Atlanta
    My Daughters Prius 3rd Gen the Passenger headlight isn't getting any power. With a meter there is no 12V.
    I have had the engine compartment fuse panel off, and where the low-beams are position 20 and 29 there isn't either fuse present, and the fuse sockets are empty of contacts.
    So Since the Drivers side work, the hi-beam fuses are good so is fuse 24, need a little help.
    the light that doesn't work is a 9005, but the h11 is labled as the low beam? So where do I go from here
    and what color should the lights have going to them that is h11 vs 9005, as they are both wired the same.
    h11 9005 . 9005 h11
    I have taken off the connector and there isn't any power there either.(passenger side) drivers side works fine.
    52,706
    have you tried a new bulb?
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Assuming the light was previously working for your daughter, has the car had any recent damage or work performed that may have caused the socket to loose power?
