2012 ABS Codes C1252, C1253, C1256
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Janeeko7777, Nov 18, 2019.
  1. Janeeko7777
    Janeeko7777 New Member
    Michigan
    Hi. I drive around 100 miles per night delivering papers. A lot of stop and go driving. Lately after driving awhile, the Traction and ABS warning lights come on and I end up getting a hard pedal, like manual brakes. Then after some time they will turn off and everything is good again. It is an intermittent problem and happens in many different driving scenarios. Dry weather, rain, warm or cold. I need to replace my rear brake pads. I don't know if that could cause the code. I scanned it and these are the codes C1252, C1253 and C1256. I hope someone can help. I'm poor and hoping it's something I can repair myself or my mechanic friend can. Please help...
    Thanks for anything you can do.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Sounds like the expensive accumulator
  3. ChapmanF
    19,058
    In a Gen 3 there's an actuator assembly and an accumulator assembly, separate items, and they're both kind of expensive and inconvenient to access for replacement. The codes, I'm sorry to say, could implicate either item; what the codes really mean is that pressurized fluid isn't holding pressure well in the accumulator, but that could be because of a sticking valve, and most of the valves are not in the accumulator assembly but in the actuator. So it's possible for the accumulator to be innocent victim in this scenario.
    Considering the expense and tedium of replacing either one, any preliminary investigation to try to pin the blame more clearly on one or the other might save some frustration.
    Tbkilb01 likes this.
  4. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    image.jpg My 2011 198k...lit up the dash ...C1256... I hear hissing and see seepage at brake booster boot under dash. Raiding the parts off My wrecked 2010 donor to check compatibility..hissing under the dash gradually got louder and seepage is visible when pull back boot...the accumulator was cycling more and more frequently about every 10-13 seconds. I’m just going after booster/accumulator assembly code C1256 points to accumulator low pressure and I see leakage and hear hissing under dash at brake pedal where connects to assembly thru firewall.
    #4 Tbkilb01, Mar 21, 2023
  5. ChapmanF
    19,058
    The two assemblies are connected to each other, so the accumulator pump will have to run more, and you can get the same accumulator low pressure code, no matter which unit has the leak. More often it's the top one. The top one is also the one the boot is connected to under the dash.
  6. Tbkilb01
    218
    187
    Louisiana
    F3181D81-5E17-4373-8249-2C37A1FAEF16.png BF191ABD-509D-4DA5-BEEC-0780AF897C48.png AB0CE883-138A-41F7-8B8C-DC39571CC790.png 73E081BD-A0B7-455E-9599-E62CDBAED3D8.png F672C8F2-E89C-4E27-96C2-4E1DE60A4F6A.jpeg Got the donor 2010 accumulator out today. The leaking accumulator cycled from 3.23V then up to barely 3.7V the decay was rapid as well... 2011 @98k accumulator kicked on at same 3.23v. Cycled to a strong 3.78v and slowly decayed to 3.23v and repeats...I’m not messing with pump at this point Toyota replaces both components.. but they always CTA for Toyota...
    #6 Tbkilb01, Mar 21, 2023
  7. Tbkilb01
    218
    187
    Louisiana
    Visual inspection revealed the failure... EBDF37D0-246B-41C2-B976-DEFEEE33D416.png
    hissing and leakage at brake pedal under dash..
  8. Tbkilb01
    218
    187
    Louisiana
    Leaking Actuator
    Need enough fluid
    don’t let run low during bleed
    Did the swap.. no problem
    put on all 4s
    Backed up battery...
    .. actuator cycles very quickly reaching upper limits and holds pressure steady about 3.5ish ...
    Responds to braking...Nicely
    Accumulator Pressure voltage should hold steady... very slow decay...down to 3.23 volts Then cycle... no hissing no weeping. Funny that Boot has weep holes built in ...
    #8 Tbkilb01, Mar 24, 2023
