2012 Camry / Camry Hybrid to be Revealed on 8-23
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by DeadPhish, Aug 22, 2011.
  1. CPSDarren
    CPSDarren CPS Technician
    533
    112
    Chicago
    Assuming you believe driver death rates were a good indicator of safety, back then when they did even less adjustments for driver demographics. The variations among corporate twins alone are a good demonstration of the variability, even among identical cars that have very similar demographics of buyers/drivers.
    Some trends are clear, even though current results can't be compared to past death rates due to how they adjust numbers.
    Personally, I wouldn't want to be driving my kids in a 1999-2002 SUV. I'd rather put them in our 2010 Prius without a hint of doubt, but YMMV.
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Sure, but in 2002 you couldn't get a 2010 Prius.
    Do note that the adjusted death rate was MUCH higher for 2WD SUVs than 4WD. (See page 13 again), suggesting that reference to an overall average is not a good indicator to say that none of them were safe.
    You're right of course that the adjusted death statistics can't tell you everything, both because of missing factors and that it's only deaths, but, I'd have to use the best information I have.
    Of course, I still wouldn't have an SUV or minivan because I think the safety trade-off to a smaller, more economical vehicle is worth it. I just won't go to a motorcycle.
  3. CPSDarren
    533
    112
    Chicago
    That's another issue I mentioned. Even in the most recent results that cover only through some model year 2008 vehicles, many current models are not even considered. You can get a 2010-2011 Prius now, but the death rates give you no information to compare to any other new model, let alone a 2002 SUV where they used a different method to calculate death rates.
    My opinion is that the rates are simply not a good indicator at all to compare vehicle safety. Based on crash test results (often mediocre where available), the relatively high rollover propensity and lack of stability control, that is why I personally wouldn't consider an SUV from 10 years ago as safe enough for my family compared to other choices. Whether they are safe or unsafe in absolute terms is subject to debate, obviously.
    That can be a fallacy, too. The only information available or the best information available can still be wrong. Just compare the Grand Caravan to the Town & Country in the 2011 study. The GC has over twice the overall death rate. In terms of overall safety, they should be identical. Even though the IIHS admits that they can only go so far adjusting for non-vehicle factors, these two should have pretty similar driver demographics. Sebring/Avenger, Marquis/Crown Vic, Magnum/MagnumHemi, Montana/Uplander, Aura/G6 are models that jump out offhand as varying by as much as 50% in overall rates for identical models. Some of these don't even overlap on their 95% confidence bounds!
    For safety comparisons from one vehicle to another, I don't personally don't find this to be the best information we have, or even good information. For example, I personally wouldn't choose something like a 2005-2008 Suzuki Forenza (overall 62 rate) or 2008 Ford Escape (42 overall) over the new '08 Chevrolet Malibu (overall 67). Even though the driver death rates imply the Forenza and Escape are safer, the crash tests results from the IIHS and NHTSA for the new Malibu are very impressive, while those for the Forenza are not nearly as good overall. Maybe the Forenza and Escape are standouts at crash avoidance capability compared to the Malibu, but I doubt it.
    Of course everyone has their own preferences/tradeoffs and safety isn't the top priority for very many buyers. If safety was my only concern, I'd probably have purchased another Odyssey this year. I'm still very confident our Toyota hybrids will do a good job avoiding crashes and protecting us if we are in one.
    Suffice to say that there are a lot of safe choices today, especially in the SUV and truck markets. While I believe it is impossible to use driver death rates to compare one vehicle to another, the trends are pretty clear. Safer vehicles and increased use of seatbelts has brought highway fatalities to record lows. Consider how many more vehicles and miles driven today than there were 20 or 40 years ago and that is an accomplishment.
  4. austingreen
    austingreen Senior Member
    13,676
    4,214
    Austin, TX, USA
    At least on a technical level it seems toyota has done a great job on the new Camry hybrid. I think at that price point the camry hybrid will get a bigger share of the midsize market and get more people driving green.
    I'm sure it is a safe car. People seem to overestimate the chances of dying in a car, and am not sure why the SUV versus car safety is in this thread. The key in the weight catagory is conservation of momentum meaning that change in velocity will be = v1 - (m1v1 + m2v2)/(m1+m2) if the cars stick together.. Injuries happen with the change of velocity, and the lighter car will change velocity more. But the differences in height may make up more of the difference. I could not find anything more recent than this
    e:\dot\ltv html\ltvissues
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Not sure if it's been mentioned already but 2012 Toyota Camry First Drive says:
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Pretty much the advancements made in 2010 Prius.
    Interesting, just like Gen2 Prius MG2.
    Smart move!
    Source
  7. cwerdna
    12,544
    2,124
    SF Bay Area, CA
  8. CPSDarren
    533
    112
    Chicago
  9. austingreen
    13,676
    4,214
    Austin, TX, USA
    One other tidbit
    Winding Road | Driven: 2012 Toyota Camry
    I think if you liked the camry hybrid before, you will like the 2012 even more.
  10. CPSDarren
    533
    112
    Chicago
    If it gets better crash test results than the current one, I'll like it a lot better except for the front end;-)
    Sadly, my co-author gets all the Toyota/Lexus for review. I was envious with the CT200h. I've got the new Mazda5 and refreshed Honda Pilot instead. Not sure when I'll have a chance to check out the Camry Hybrid. There's a "green" auto show in town next week, maybe they'll have one there.
  11. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    crash tests are going to be fine... it is also one of the few cars with standard 10 airbags, even most of the 3x more expensive luxury vehicles have them as option (rear side airbags).
  12. bisco
    51,961
    i don't plan on crashing.
  13. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Does anybody know which Camry has Paddle Shifter with Revmatch?
  14. Tideland Prius
    16,559
    It's interesting that most, if not all reviews that I've read on the 2012 Camry Hybrid have been very positive. This is coming from a group of journalists that would rather have a 3 series than a Camry.
    That looks pretty good to be. The trunk is well shaped and it has the biggest pass-through of any hybrid sedan (and judging by the picture, it looks taller than the previous Camry hybrid). The HCH-III doesn't have folding rear seats even with a Li-Ion battery.
    because the fuel tank doesn't take up trunk space so a smaller tank wouldn't mean a bigger trunk. In the old TCH, it's possible the battery intruded a little into the fuel tank's space hence the 0.5 litre reduction in size.
    The Prius has a Cd of 0.25
    Yeah I saw that on toyota.ca. I'm still betting on my 5.0L/100km or better number. (Do you think they'll hit the important 60mpg Imp./4.7L/100km number?)
    That's the Toyota Sai, the Japanese version of the HS250h (probably decontented too)
    The SE models though I'm not sure if it's limited to the V6 or to both SE and SE V6 models.
  15. Tideland Prius
    16,559
  16. CPSDarren
    533
    112
    Chicago
    As long as the other guy doesn't plan on it either, you're good!
  17. Tideland Prius
    16,559
    Anyone noticed the lack of an adjustable rear centre headrest? It appears to be a fixed centre headrests (I can't tell if they're the same on the outboard headrests. They look like triangle/pyramid cushions lol).
    Also it appears that the reclining rear seat wasn't the only thing that was chopped on the XLE models. The rear sunshade was also dropped.
  18. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Only the fog lamps not my taste. Others are nice.
  19. CPSDarren
    533
    112
    Chicago
    Decontenting? Those were nice features. Toyota also took a step backward on the new Sienna in regard flexible seating for larger families with the tiny 8th seat and removing LATCH seating positions.
    Yeah, full cutout foglights might help. The trapezoidal black hole at the bottom like on the Highlander Hybrid is almost like the styling group gave up.
  20. Trollbait
    12,543
    Plus, it's cheaper for Toyota to use the same fuel tank in the entire lineup.
