2012 Camry Hybrid Offset Steering Wheel Oddity
Discussion in 'Toyota Hybrids and EVs' started by cycledrum, Jan 20, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Anyone like their steering wheel a bit to the right?
    2012 Toyota Camry Hybrid XLE Steering wheel offset maybe two inches right of seat. Camry L, LE, XLE and Hybrids like this.
    2013 Honda Accord EX-L
  2. DoPeY5007
    DoPeY5007 Member
    122
    17
    my Prius C is not straight, I thought it might have been the alignment, it may have the same issue.
    It is slightly off, and yes it bothers me a ton.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Not me, I've had car with a bigger offset and soon got to the point that I didn't notice it.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Are you t talking about the wheel being turned a little while going straight down the road (that is fixable). A wheel askew laterally is so not fixable.
    And I think, but not sure if I recall, the Prius c wheel was a little askew, laterally (?) shifted to the right a bit.
  5. PriusCamper
    PriusCamper Senior Member
    13,433
    5,422
    Pacific Northwest, USA
    Maybe if you always drove with one arm it could be considered a Toyota ergonomic design to make your one arm more comfortable? :p
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    And if you switched to the other arm, it would be that much more uncomfortable from reaching further.
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Interesting... I've only test driven the '12 HyCam once or twice, maybe only once. I've never noticed this. I'll have to take a look the next time I'm in one.
    I doubt it'd dissuade me from getting one. If my 06 Prius were to be totaled or stolen, I'd probably be replacing it with a Gen 3 Prius, a PiP or a '12+ HyCam. I doubt that even if I did notice, that it'd be enough to make me switch to anything else. I just don't see any viable alternatives.
    It sure didn't prevent almost 405K units from being sold in the US last year (Top 10 Best-Selling Cars of 2012 - KickingTires).
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Yeah, they sold tons of the cars last year. Obviously most people don't notice or care about those things.
    One could drop a plumb type line down from center of wheel and see where it lands in relation to seat bottom pad.
    I sat in a non-hybrid LE also, and same situation for me as the hybrid. I was a bit shocked and did not expect to see that. Missed picking up on the wheel at SV auto show.
    It was so plain to see though. Look down to seat bottom, look up to wheel center, wow, not centered.
  9. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I don't notice it in my 2012 TCH XLE. Of course I went to the Camry after driving a Prius for 9 years.
  10. bisco
    52,807
    the touch pad on my dell is off center to the left for some reason and my right arm gets tired after awhile. no idea why they designed it this way.
  11. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I noticed my steering is not perfectly lined up with the driver's seat too - it's skewed off center to the left. Perfect placement should have the center of the steering wheel lined up with the center line of the driver's seat. I"m aware of it everytime I drive, but I'm used to it now.
  12. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Ok, that's good to know.
  13. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    2 photos added to first post.
    Did the same string measurement on my Prius before going, found string pretty well aligned to center of seat bottom. From what I see, where is Toyota's attention to detail on Camry?
  14. PriusCamper
    13,433
    5,422
    UPDATE: Oh... I stand corrected, looks like you did measure....
    How do you know it's not a optical illusion? Have you actually measured? I mean when I look at steering wheel placement on my Gen2 Prius it looks off, but if I close my eyes it feels perfectly centered. I as well have yet to measure... PS: Don't close your eyes while driving, it's dangerous! :)
  15. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    OMG!!! A 1/2" off?!! Someone should sue.
    All kidding aside.... I'm sure there is an engineering reason for it. Maybe the steering column had to be offset a 1/2" to accomodate a component in the engine bay. They probably figured that this offset was insignificant enough that most people would not notice it.
  16. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    it looks bad to me, there's an airbag in the wheel, I'd prefer mine directly in front in case. Least I won't be tempted to change to a Camry in a few year. The wheel thing plus extra headroom is minimal with sunroof cause they're a little stingy with how much the power seat can lower down.
    back to topic.
  17. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Quick glance from left seat bottom tuck just about lines up with left edge of steering wheel. Right edge of steering wheel appears at least an inch to right of right seat bottom tuck.
    Seen the same thing in C-Max, Sienna, Passat and others forgotten about at moment.
  18. iuswingman
    iuswingman New Member
    I test drove a '12 Camry Hybrid last month and didn't notice anything being off with steering wheel location.
    If it's off-center, then it's not enough to matter in my honest opinion.
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Here's a pic off Toyota's website of the 2012 interior. It's not from straight behind the driver's seat, but I will get a photo that way. The wheel offset will be plain as day, wait and see.
  20. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    Ive noticed this in the GM/Chevy trucks and full size SUVs(Tahoe, Yukon, Suburban) for years. Dealers say its normal. [​IMG]
    cycledrum likes this.
