2012 Camry Hybrid Offset Steering Wheel Oddity
Discussion in 'Toyota Hybrids and EVs' started by cycledrum, Jan 20, 2013.
  1. acdii
    acdii Active Member
    1,124
    131
    I find that some seats tend to press against my left thigh in such a way that my leg starts to ache, I didnt seem to have that problem in the Camry, nor the Avalon.
    I really wish I could have afforded the Avalon, what a nice ride it has.
  2. Tideland Prius
    16,675
    I believe the Avalon Limited has a powered cushion length adjustment.
    cycledrum likes this.
  3. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    Man, you should change the title of this thread. It's overly dramatic. I'm just started looking into 2012 Camry Hybrids and your thread title had me worried. :LOL:
    cwerdna, xs650 and Blu-ray like this.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I would but only the moderators can change it. I'm seeing a few offset steering wheels here and there - Passat, new Sienna, C-Max,
  5. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    I drove a 2012 Camry today. The wheel is not a problem.
    ADR6425LVW ? 2
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Drove new Camry SE for couple hours this morning. Offset steering wheel a deal breaker. Car was ok overall but I'd think Accord driving experience has Camry whupped.
    Pros: secure handling: Much better than Prius, fairly quiet, quiet engine (could hardly tell it's running at stop light),
    Cons: offset steering wheel (hate it), feel road bumps fair amount in SE, 5 spd tranny shifts for highest gear asap, can bog entering freeway, stock sound system like all base systems: makes bunch of midrange noise, no bass, yuck,
  7. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I see from the picture the Camry steering wheel seems a bit offset to the right - the Prius it's the opposite where it's offset a bit to the left. Before settling on the Prius v, among others I test drove a Camry SE and XLE Hybrid and the steering wheel position was not a factor for or against. The SE rode stiffly and seemed a bit spartan on the inside and was only considering it because of the killer lease deal, and the Hybrid drove nicely and I would've bought but it didn't have the utility I wanted. Since it practically gets the same mileage as the v, having the 2.5 liter hybrid system in the v would be awesome!
  8. Tideland Prius
    16,675
    Isn't it a 6 speed? I didn't think manuals were offered any more on the Camry.
  9. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I don't know if it's still true, but a few years ago manual transmission was available in the Camry on a regional basis (available in New England, not in Great Lakes, for instance).
  10. Tideland Prius
    16,675
    That was the Gen 6 Camry. That was available with a manual transmission. For the 7th generation (launched for the MY2012), there isn't any transmission option. It's a 6-speed auto w/ manual mode for all non-hybrid Camrys.
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Right, it is a 6-spd automatic. I can tell it's programmed to shift up through the gears as quick as possible. Must be for fuel economy.
    Downloaded free Photoscape software. Little bit of skew in camera angle, but not much.
  12. Lisa Jean
    Lisa Jean Junior Member
    35
    the car is too low for me.
  13. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Decide for yourselves ....
  14. Lisa Jean
    35
  15. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    No, they could adjust it if was turned a bit while going straight down road, but nothing else.
    You have tilted the wheel down more, right? And telescoped to you if needed?
    From this pic camera 550.jpg you can see that my elbows have a place to rest, right? Do you have any shot at using the armrests, both of them while driving, even if that means fashioning 5 or $10 of foam to be able to do so? Stressing your arms to handle the wheel could be making your seating / back much worse. If you can get a good bend in elbows while steering, needing armrests would seem much less of an issue.
    That 4" stack of foam on armrest has made the biggest improvement in seating comfort, no more futzing around trying to get a grip on the wheel which btw, is quite far from me due to long legs (and arms) as you can see MCCOY BRETT.jpg and very limited steering wheel telescope. This car is not so 'vertically challenged' seating wise, but quite 'horizontally challenged' and not in a good way.
    Because some cars are designed with drivers in mind, others are made as appliances with 4 wheels.
  16. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
  17. bisco
    52,808
    if she doesn't know she has a tilt steering wheel, i think we're tilting at windmills here.
  18. Lisa Jean
    35
    some tall folks might wish it telescoped closer.
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Um, yeah, the wheel tilts up and down as well as telescopes. Release the lever all the way down, adjust, but secure it before driving!
  20. bisco
    52,808
    of course, the manual is almost 700 pages. that scares most people away...
