2012 Camry Hybrid tires and inflation
Discussion in 'Toyota Hybrids and EVs' started by Stargazerwa, Nov 5, 2015.
  1. Stargazerwa
    Stargazerwa Junior Member
    38
    WA
    just replaced the factory tires on our Camry with Michellen "Energy" tires from Costco. Our mileage seems to have dropped ever since. What are folks experience with these tires and what inflation pressures are people running? I know that many Prius owners use more pressure then Toyo reccomended.
    52,860
    it may take some miles to break them in. we run our oem's at 42.
  3. Trollbait
    12,831
    New tires will always cause a hit in fuel economy. Remember, your previous numbers were on old tires that were likely well worn, and thus had a lower rolling resistance than when they were new.
    Higher pressures will also reduce the rolling resistance, and I have mine set to sidewall max.
  4. Mendel Leisk
    42,351
    Could you post the full, kosher name of the tire? Michelin makes several tires with the word "energy". I'm guessing it's "Energy Saver A/S", is that it?
    Also, how how long is "ever since", a month, a year? If it's just the last tank or two, it could be new tires, seasonal vagaries, trip type.
  5. Stargazerwa
    38
    WA
    They are the Energy Saver A/S and Costco installed them with 39.5 psi according to my gauge. I kept the original set of tires at Toyota's spec which is 35 psi. Tomorrow I will up the pressure to 41. It has only been a few hundred miles, but the difference in mileage is noticeable on each trip since the car displays it when you shut off the engine. The cars averages was running 40.3 since 1/1/15 and since buying the new tires it's dropped to 40.1. To be fair, we live in the PNW and our temperatures are dropping and that will impact the mileage. The tires are quite and have better traction in the rain.
  6. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Err, did you go from a 195 tire to a 185 tire, that would effect things, yes, the michelin will get possibly 1 mpg less after break in but the safety and security as you find are worth it.
  7. Mendel Leisk
    42,351
    I think you're fine. The difference in mpg is very small, your sample is only a few 100 miles, the tires are very new, and as you said the weather's getting colder/wetter.
    Trollbait likes this.
  8. Stargazerwa
    38
    WA
    They are the correct size, it's an oddball on the 2012 model. I wI'll increase the pressure to 42. I gues the other thing is that new tires would have slightly larger circumference, which would make the cars computer believe that it is traveling a shorter distance dropping its calculation of speed, mileage and economy. I don't know how small that effect would be. We have spun out on wet roads with the old tires, no evidence of that with these tires. Last year we averaged 39.9 over 12 months, it will interesting to see how we finish this year and the next. Considering its size we are very pleased with the mileage.
  9. Stargazerwa
    38
    WA
    I raised the pressure to 42 and I definitely feel bumps in the road more. Reflecting on this I think it was unwise of me to jump to conclusions. Two variables that impact mileage, air temperature and tires, changed at the same time. I will have to reevaluate in Spring! Thanks for all the help.
  10. bisco
    52,860
    what about winter gas?
  11. Trollbait
    12,831
    Plus denser air and thicker oil on startup.
    Among the variables, everything gets worse for fuel efficiency in the winter.
  12. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    That much of a drop in fuel mileage is not worth worrying about. I would bet its the lower temps. i average about 43 with stop and go short trips around town and about 46 at 75 to 85 mph on highway. I keep tire pressure at Toyota specs for smother ride and less wear and tear on suspension. I leave it in normal mode and drive it like i would any other car.
  13. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    My 2013 Camry Hybrid came with Michelins. Just replaced them after 49k miles avg 39.6 mpg. I replaced them with some Cooper non LRR I got for $180 a set from Discount Tire Direct. My mpg is now around 36 to 37mpg.
    That difference is noticeable...
    iPhone ?
    lar.smith42 and bisco like this.
  14. Stargazerwa
    38
    WA
    My mileage this year dropped to 37.7 with the new tires. 2 mpg lower than the previous two years
  15. bisco
    52,860
    but starting november 5th, no summers in the average. check back in on october 31, 2017.:cool: and you can lower the pressures if the ride is too harsh.
