2012 Camry - time for new traction battery?
Discussion in 'Toyota Hybrids and EVs' started by rwheels, Nov 17, 2022.
  1. rwheels
    rwheels New Member
    Temple, TX
    Hi Folks,
    We have a 2012 Camry Hybrid with ~165k on it.
    This morning, the 'Check Hybrid System' warning appeared on the dash with a few other lights:
    I downloaded Dr. Prius for the first time and used an old Bluetooth OBDII dongle:
    Does this definitively point to a traction battery that needs to be replaced? Or are there other things to be checked before making that decision?
    FWIW - After taking the above screenshot, I cleared a code P0a80 with Torque. The 'Check Hybrid System' and other warning lights cleared from the dash. I switched back to Dr. Prius, and now block 11 looks average, and block 4 looks low:
    Thanks!
  2. rwheels
    rwheels New Member
    Temple, TX
    Also - forgot to note that Dr. Prius life expectancy test showed ~25%. I have NOT yet run a full battery test, but will once I've got a few minutes to find an open stretch of road.
  3. Trollbait
    12,806
    Corrosion of the pack's bus bars have been known to cause a 'bad battery' code. Replacing and cleaning up the connection can fix it. Got to pull the pack out to check though.
  4. rwheels
    rwheels New Member
    Temple, TX
    Thanks for the reply.
    I went ahead and pulled the HV battery following a youtube video.
    Looks like there is some corrosion, but nothing that seems extreme to me:
    PXL_20221118_232124463.jpg PXL_20221118_231650534.jpg PXL_20221118_231630461.jpg
    I presume at this point it's worth a try to clean those bus bars and see if it helps, or replace with some nickel plated ones?
    If I don't have any special equipment beyond a pretty basic multimeter, I presume I should probably not attempt to balance the modules?
    There seem to be mixed opinions on 'rotating' the blocks - is that something you all would recommend?
    Thanks!
  5. Led
    Led Junior Member
    37
    Huntington WV
    First, do not use the nickel plated bars. Dr. Prius has a video why on his YouTube channel.
    Second, my wife drives a 2013 Avalon. Its battery was upgraded with a Lithium pack last December. I don’t regret spending the money. It’s been flawless.
    Thanks
    Stephen
