2012 Daytime LED Running Light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2012 Prius classic silver, Apr 12, 2012.
  1. 2012 Prius classic silver
    Port Jefferson station
    Does anyone know how to have the Daytime Running light stay on as the Low Beam is turned on? Please help if you know. The LED Running lights are definitely cool.
  2. _tran
    _tran New Member
    Patterson, CA
    bump. i would like to know if this is possible as well
  3. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    On mine, a mdl II, there is off/ parking light/ running light/ headlights in that order on the indicater arm, mine has no 'auto' position. leave it in running lights, they will turn off when car is shut down, thru the radio you can adjust how long they remain on after the car is shut down. BUT, you need to put the headlights back on at night.
  4. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    By design the DRL's turn off when the lowbeams are energized. The manufacturer assumes you no longer need DRL's since you're using your lowbeams.
    You'd have to wire in an additional headlight relay to power the DRL's when the lowbeams are on.
  5. 2012 Prius classic silver
    gotcha..thanks for the insight. I guess I need a headlight relay.
