2012 DRL's on at night?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Muzzman1, Feb 19, 2012.
  1. Aquos
    Aquos Junior Member
    49
    houston tx
    did you wire to drl relay or straigt to drl? Can you explain more on what way you were able to do this mod?
    Thanks,
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The 12v pos wire coming from the OEM DRLs will be tapped to the fuse that I showed. When the Prius goes into ready mode it will turn on the DRLs & will stay on with the headlights on until u power down.
  3. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Any trips to the LA area anytime soon Sean?
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Everyday M-F. I work in Commerce
    I make trips out there on the weekends when the wife wants to visit her family
  5. scooter4n
    scooter4n Junior Member
    27
    27
    I saw that fuse earlier when I was doing under the hood thing. SO I removed it, LOL, that cleared my ECU settings, clock, calendar, trip, and warning "stop and check your Hybrid system" started flashing. Had to go to dealer to reset that, LOL
    I dont want to mess with ECU fuses, thats bad news waiting to happened
    Can anyone point me to headlight relay, or parking light relay???
    I did check all of the fuses under the hood, and this 3 10AMP are only fuses that are shut down when car is off.
    On the side note, you will need positive and negative to the DRL relay, because both + and - gets desabled.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U must of powered up cause I've had that fuse out (never powered up) & never had any problems
  7. scooter4n
    27
    27
    cant remember, maybe did, not sure.
    Anyway, Im not sure I want to mess with that fuse.
    There has to be ACC connector in that fuse box.
    and on my 2012 model Low Beam fuses and relay are not there where they are marked.
    Probably got moved under the dash
  8. El Nino
    El Nino Member
    210
    Michigan
    The fuse that I used is one that a stereo install guy found for me...but I think there may be a better one since this one is tied to some things that I would hate to mess up. Any of the other 10amp fuses you can see Sean that may be a better fit for our needs? The DRL's use very little juice so I'm not really worried about ever blowing it...but you can never be to careful. I think the "off and on 3 times trick" resets the car if you encounter that bothersome hybrid error.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    There is only 1 other option tat I am aware of & it's a wire that runs to the windshield wipe motor. It hot when ready.
  10. peterjmc
    917
    189
    Clarksburg, MD
    Would anyone be able to help me figure out the wiring for my DRL desire? Figure it might be good to piggy back off this thread or maybe I should make my own thread.
    I have a 2013 Prius Five.
    I like running "parking lights" as DRLs for all the cars I've had since it also illuminates the tail lights.
    My Prius has "Auto" on the stalk and automatically switches between DRLs and headlights on. Instead of just DRLS, I'd like this "Auto" to flip between Parking lights and Headlights. I could just as easily just flip the knob when needed, but I'd like to use the "auto" function.
    Anyone have any thoughts?
  11. alan916
    alan916 New Member
    Bay Area
    2015 Prius Plug-in
    Thread Revival alert! didn't want to create a new thread, so just piggyback on this thread..
    Anyone have a pic of the location of the DRL red 12v hot wire near the bumper? or is it easy to find by just following the DRL wire bundle? sorry just want to get this straight before I remove my bumper to do this.
  12. BPZVW30
    BPZVW30 Member
    73
    141
    This is on my mod list along with LED headlights.
  13. alan916
    alan916 New Member
    Bay Area
    2015 Prius Plug-in
    Ok I think I found the wire.. One more question, do I connect an extra splice from the passenger drl to the driver drl then splice that to the terminal?
  14. sttkailua
    sttkailua Active Member
    190
    151
    Hawaii
    Scooter,
    I also have a 2013 Prius 2.
    I am new to the site, and was looking at posts for connecting DRL to run with the headlights.
    Would look like faux-fog lights with the headlights on.
    I also want the DRL to operate as it does now.
    What would an auto 12v diode look like? Would it come with wires ready to connect, or would
    you need to do some soldering?
    Thanks
  15. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Use a 1N4001 or 1N4004 diode, available from any electronics supply store, or eBay.
  16. sttkailua
    190
    151
    Hawaii
    xlider,
    Thanks for for help.
  17. fuzzy1
    10,613
    Maybe even still at Radio Shack, if any still exist in your area.
  18. sttkailua
    190
    151
    Hawaii
    fuzzy,
    I just got back from Radio Shack, and got 1N4001.
    They are still in business(barely).
    Current flows from anode to cathode, I read.
    So, just need to find the correct wires to connect to without
    shorting anything else!
    I did install fogs with harness on my
    2009 Camry Hyb., so I have some hands on experience crawling under
    a car and running wires.
    It is easier running new wiring, instead if finding correct existing
    wiring that is all bundled/wrapped up.
    Thanks for your reply.
    Dylan Doxey likes this.
  19. sttkailua
    190
    151
    Hawaii
    xlider,
    I can visualize connecting the headlight relay to the DRL relay with a diode.
    The location shown on the fuse cover for H-LP relay, there is nothing there.
    Is there a headlight relay to connect to?
    On another thread regarding 'DRL mods. 2013', you and others recommended using
    a Low-profile fuse tap connecting the headlight fuse to the DRL positive.
    Which one would recommend to use?
    thanks,
    stt
  20. sttkailua
    190
    151
    Hawaii
    scooter,
    Did you ever locate the headlight relay?
    I did buy a diode, and am ready to do the connection.
    In another thread, on DRL mods. 2013, posters were using
    A low profile fuse tap to the headlight fuse. The DRL relay is pulled out. The wire is
    Fitted with a splayed male connector and plugged in.
    After some thought, I was going to use the fuse tap on the headlight
    fuse, connect the diode to the wire, and dremel a slot around the relay
    Housing. II would connect to the DRL relay, which would stay in place.
    what do you think? Looking for the simplest wiring, but want a nice looking
    wiring mod.
    Thanks,
