2012 fuel gauge prob.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Peter Cockroft, May 3, 2021.
  1. Peter Cockroft
    Peter Cockroft New Member
    New Zealand
    Can someone help..... sitting at the lights the other day the fuel gauge had lost 3 of its 10 light bars suggesting the tank was a third down. The fuel figure at the left end of the heads-up display said I had about 640 kms to go before I needed to fill up.....as I watched, the fuel gauge counted down the light bars and left the bottom one flashing ....and the fuel figure said I had 12 kms left before I had to fill up and it flashed too !
    It took just 16.5 litres to top up so still had heaps.........any ideas greatly rec'd
  2. Mendel Leisk
    42,355
    Maybe the float gizmo in the tank sprung a leak?
    52,863
    does not sound like a simple diagnosis unfortunately. how is the 12v health?
  4. Peter Cockroft
    New Zealand
    After I filled up the fuel lights showed full, and the heads-up display said I had 940km to travel before needing to re-fuel again......
  5. Peter Cockroft
    New Zealand
    Hey Bisco, how can I check the health of the 12v ?
    ....thanks
  6. bisco
    52,863
    put a volt meter on it, then run the headlights for 5 minutes for a before and after load voltage comparison.
    here, auto parts stores will perform a free test with an electronic load tester. might be worth calling round
    #6 bisco, May 4, 2021
  7. Peter Cockroft
    New Zealand
    much appreciated, thanks Bisco
