2012 Gen 3 Prius. Engine shaking when accelerating.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Darth_Eric, Mar 14, 2025.
  1. Darth_Eric
    Darth_Eric Junior Member
    San antonio, texas
    2012 Toyota Prius 125K miles, well maintained and taken care of. Just started getting some shuddering and shaking coming from the engine it feels like when accelerating. My coolant levels are solid and, have kept up on regular oil changes. My only guess would be EGR cleaning? maybe its clogged or Engine mounts? or Water Pump. I've cleaned the battery fan and changed the spark plugs myself in the past year. I've also noticed lack of power i know thats relative with the prius but seems to be more then usual. Any ideas on what it could be? No check engine light. Also it used to burn a lot of oil when i lived in texas and drove a lot more. Now i moved back home to Seattle and it doesnt seem to burn any oil at all at least not that ive noticed
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    egr was never cleaned then it wasn’t “well maintained. Git r done.
    52,742
    Might as well start with the egr circuit, you need to do it anyway, if it isn’t too late.
    Maybe do a leak down test first?
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,947
    6,868
    Texas Hill Country
    Coolant loss is undetectable at first; Borescope is definitive; others can provide false negatives
  5. Mendel Leisk
    42,223
    Info on EGR cleaning and head gasket remediation in my signature (on a phone turn it landscape to see signatures).
    Neglected EGR cleaning and head gasket failures are like peanut butter and jam with the 3rd gens, and v’s. :)
