2012 Hatchback Lid Light Cover
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DavidinNevils, Dec 8, 2024.
  1. DavidinNevils
    DavidinNevils Junior Member
    42
    Georgia
    OK, I tried about 20 different Search terms to find this and nada ...
    Please see three attached images.
    The plastic cover for the exterior light on the hatch lid has failed on the left side - cracked at the screw.
    Can someone share what that fixture is called (or the part #) and where I might find a replacement, please?
  2. PriusCamper
    PriusCamper Senior Member
    13,387
    5,409
    Pacific Northwest, USA
    There's plenty of wrecked Prius at junk yards these days and pulling one of those off a vehicle is like $10 or less. Whereas if you tried to buy one from a Toyota Stealership the price they charge will be outrageous.
    PS: The photos are of a Gen 3 Prius (2010-2015) and not a Gen2 Prius (2004-2009).
    6079smithw likes this.
  3. 6079smithw
    6079smithw Junior Member
    N. Nevada
    Third Brake Light Lens Assembly, and Mr. PriusCamper is correct.
    My local stealer quoted 79-something plus tax. The boneyard is
    your friend here...
    #3 6079smithw, Dec 8, 2024
    DavidinNevils and PriusCamper like this.
  4. Tombukt2
    Tombukt2 Senior Member
    13,798
    2,501
    Durham NC
    Yes because you have to buy complete assembly it's LED so crack makes almost no difference . Inspection should no matter it's correct color and lights w no visible issue seeing it . Usually how law is written . I've two plastic headlights lenses they can't fail me on because of this issue . They bright they burn . And functional.
    DavidinNevils likes this.
  5. DavidinNevils
    42
    Georgia
    Thanks, ooops ... we have an '08, '11, & '12 here. I forget generations.
