2012 Head Gasket Replacement - Timing Chain Tensioner won't insert
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chase B, Apr 9, 2026.
  1. Chase B
    Chase B Junior Member
    2012, 249k miles, attempting to do a head gasket replacement on my own. Things have gone...mostly OK, but I am at the point where I am trying to re-insert the timing chain tensioner and it will not insert. When putting my fingers through the hole it feels like there is not enough room for the locked in place tensioner to insert, and I'm wondering if the plastic chain guide is blocking it, as I can certainly feel the chain guide with my finger when inserting into the hole. I'm more than a little worried the tensioner guide is not seated correctly. Has anyone had this issue, and if the chain guide isn't seated correctly is there any other option other than taking apart the timing chain cover and starting over from that point? I'm confident the chain guide was inserted into the hole at the bottom, but there were times when it would shift to the left (although I didn't think it did before I put the cover on).
    #1 Chase B, Apr 9, 2026
  2. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Is there a chance that's due only to tension on that side of the chain, which you could relieve by pushing on it or by rotating the crankshaft forward slightly?
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    When the timing cover is mounted back up, the chain slipper hugs tight enough on the chain and you can insert the chain tensioner back in. The slipper doesn’t have any room to obstruct the chain tensioner being inserted once the timing cover is back in.
    if you still can’t fit the chain tensioner back in. Remove the timing cover and redo the rtv/fipg seal but this time, use mechanic wires to hold the slipper and chain in place against the top of the chain so it doesn’t slip to the left.
  4. Chase B
    Thanks to you both for your comments/suggestion; NAB I watched your video (and rewound, and rewound...) and saw the wire trick. I ended up taking the cover off and actually putting the tensioner in while the cover was off but just ever so slightly starting the bolts back on the studs, and this seemed to work OK as I was able to fully tighten the tensioner on the studs once the cover was back on.
    Although it took me way longer than even I estimated, I think she's all back together in one piece, and I've driven it about 25 miles without any engine codes, so I think she's good to go. Thanks!
    CR94, NutzAboutBolts and Brian1954 like this.
  5. cdherman
    cdherman Member
    68
    27
    Kansas City
    Chase B -- are you sure you were not putting the timing chain tensioner backwards the first try? The holes are symetrical, but the plunger part of the tensioner goes towards the block. I had to use a mirror to figure this detail out - NAB video did not have it (or I missed it)......
  6. NutzAboutBolts
    1,756
    1,789
    Bay Area
    The timing chain tensioner only goes in one way or else it won’t insert properly.
    ASRDogman likes this.
  7. ChapmanF
    19,025
    The OP may have been about it not inserting properly.
  8. Chase B
    Although I am pretty confident I tried it both ways, it's certainly possible I did this incorrectly (well, I know I did it incorrectly, but not sure what I did). But taking it apart and re-doing everything was time consuming but I believe ultimately worth it. On a side note, the 2nd time around I did a much better job not getting RTV everywhere, so in the end it was probably for the best anyway. I've put about 100 miles on the Prius since then and the only issue was when my plastic clips/rivets came loose on the undercarriage by the passenger side wheel well and it sounded like I had a blown tire. Once I re-sealed all of those with some zip ties (it's a pretty classy car) it's been flawless.
