2012 Headlights on 2011 Prius: LED Upgrade?
Discussion in 'Gen 3 Prius Main Forum' started by kevelev, Dec 10, 2018.
  1. kevelev
    kevelev Junior Member
    65
    ny
    I'm want to get new headlight housings for my 2011 Prius 2 because they ugly and worn. I have the stock headlights now, and the only thing I've changed is the Toyota recall that keeps them from burning through the low beams frequently. I noticed that the headlight housings for 2011 only work on 2010-2011 Prius, so I searched what the differences were and it appears that the 2012-2015 headlights have LED low beams (day-time running lights)? This is attractive because I had also wanted to upgrade the low beams to LED's but was hesitant because they are the projector type and the beam pattern may be affected. The 2012-2015 are also projectors (it appears), so what's the difference there? Would this be a viable upgrade?
    Links:
    2011 vs 2012 differences | PriusChat
    2012-15 Toyota Prius Headlight Pair - 1ALHP01063 at 1A Auto.com
    2010-11 Toyota Prius Headlight Pair - 1ALHP00885 at 1A Auto.com
  2. bisbonian
    bisbonian Junior Member
    On my 2012 the DRL is in the bumper and is an LED. The headlights in your link do not look like the factory LED headlights on my car, which have 2 LED units for the low beams and a Halogen high beam.
    Are you sure that projector unit is an LED and not just a Halogen headlight in a projector housing?
  3. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Only the model 5 came with LED headlights. For models 2 thru 4 on all Gen 3 years the low beam projector headlights houses a halogen bulb.;)
    m.wynn likes this.
  4. dame3780
    dame3780 Member
    61
    55
    SoCal
    I've got a pair of used halogen headlights that came off my 2011. They are in good condition. Housings are clear with no sun damage but have normal marks from highway driving. Car is garage kept. PM me if interested.
  5. High Mileage
    High Mileage Active Member
    136
    238
    2018 Prius Prime
    dame3780, the lamp housings on my are starting to get pretty foggy. I would be interested in how much you plan to ask for them. Are they factory original? Why did you replace them?
