2012 III- Engine shake and rattle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by edster, Jun 5, 2026.
  1. edster
    edster Junior Member
    Illinois
    Hello, My 2012 III has 230k, regularly maintained. At start, the engine rattles and shakes. This happened a few times since new, eventually smoothed out but didn’t last. Check engine lite on this time. Any clues? I don’t know if it can make it safely a quarter of a mile away to get it read from Autozone. Am afraid the engine may be conking out.
    Thanks for any input.
    Ed
    52,904
    most likely a blown head gasket, very common on gen 3. you're okay to drive there, but make sure the coolant is full.
    if it clatters too much, shut down and try again
  3. edster
    Illinois
    Hi again,
    I finally took it to Autozone to get scanned. The report is as generic as it can be.
    Code P0300
    Random/ Multiple Cylinder Misfire detected.
    Cylinders 1-3.
    That’s about it. So you really sure it’s the head gasket? I’m willing to get it fixed to a certain dollar amount. The car is in good condition otherwise.
    Thank you!
  4. edster
    Illinois
    By the way, don’t know if I mentioned this. All fluids seem fine. I kept reading about coolant issues. There’s more than enough, no leaks whatsoever.
  5. Mendel Leisk
    42,380
    So probable codes P0301 and P0303 as well (indicates misfires on cyl's one and three). Considering the miles and cylinders, sounds like it's advanced head gasket failure.
    If you stick with it ensure the EGR (Exhaust Gas Recirculation) system, including intake manifold EGR passages, is thoroughly cleaned. With those miles the EGR cooler should maybe just be replaced, it's interior will be badly clogged.
    There's some relevant links in my signature (on a phone turn it landscape to see signatures)
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,144
    6,987
    Texas Hill Country
  7. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Have you checked the wiring?
    Have you swopped the plugs to see if the missfires changed cylinders?
    Have you swopped the coils to see if the misfires changed cylinders?
  8. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    Does the rattling and shaking at start-up occur consistently lately? If so, that's an ominous sign. (If it's only occasional, there's usually a less serious cause.)
    Regarding the coolant level in the reservoir, the critical question is not whether it's "enough," but whether it has dropped visably in the recent past.
    Brian1954 likes this.
