2012 Interior Cloth Matching
Discussion in 'Prius v Main Forum' started by VoltecSynergy, Nov 2, 2019.
  1. VoltecSynergy
    VoltecSynergy Junior Member
    Portland, OR
    Hi Everyone!
    Unable to find another reference in this forum, this looked like the best section to post about this in. I apologize if this is in the wrong section. Let me know, and I'll remove the post.
    I need a front headrest for a 2012 v3 in the gray cloth with the swirly dot pattern, and so have been looking at salvage yard listings.
    Does anyone know if the cloth interiors were the same in the 2012 Prius Three HB and the 2012 v Three?
    I can't tell from photos that are online, nor can I find a brochure that shows this.
    TIA
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,345
    2,339
    Taylors, SC
    #2 Georgina Rudkus, Nov 2, 2019
    VoltecSynergy likes this.
  3. VoltecSynergy
    Portland, OR
    (Oops. Site was down last night, and I saw your reply after I posted.)
    Ah, that's good information. Thank you for the link to the correct part number!
    Now I need to figure out which gray I have.
    Going off the photos on the interwebs, I think I have the Dark Gray because it seems to be the only interior color that looks two-toned. (I have included a couple of photos of my interior.)
    I asked for the comparison between the regular and v models because the salvage yards don't always say whether the part came out of of v or not, or they use the color code, which I have just found the key to in another thread on this forum. All I have to go on is a photo (if they even post one). It's difficult to see if there is any pattern on the fabric in most of the photos.
    I meant 'hatchback' when I wrote 'HB', as it's the only designation I have found to describe the regular Prius model verses the v. Having never known anyone with a Prius, I don't know if the regular Prii (Gen 2 onward) have hatchbacks or trunks. They look like hatchbacks to me, but admittedly, I don't know much about the Prius yet. I'm a new, first-time Prius owner and I'm reading as much as I can.
    I'm still learning how to correctly write the different models and features. I have a v Three, which I think means a model v with trim level Three. Please correct me if I'm wrong.
    00707_4Qb2iz3YQBO_1200x900.jpg 00D0D_3UlMokvYVIk_1200x900.jpg 01010_8qYFONPuIBS_1200x900.jpg
  4. Elektroingenieur
    2,515
    3,277
    Three Touring
    You can see the color swatches in the sales brochures for the 2012 Prius v (PDF) and 2012 Prius (PDF), but more importantly, in parts catalog Figure 71-01, Front Seat & Seat Track for the 2012 Prius v and 2012 Prius, there is no overlap between the part numbers for the front headrests: the design code is xxxxx-47150-xx or xxxxx-47170-xx for Prius v and xxxxx-47110-xx or xxxxx-47130-xx for Prius.
    To know for sure—assuming the interior wasn’t replaced after the car was built—enter the VIN on Toyota’s Vehicle Specification page, or check the certification label inside the driver’s door opening. Look for “C/TR,” the three-character code for the exterior paint color, a slash (/), and the four-character code for the trim. In the trim code, the third character (for example, the 1 in C/TR:070/FA18) indicates the marketing (parts catalog) name for the color: 1 for dark gray (gray, TRIM1#), 4 for bisque (grege, TRIM4#), and 6 for misty gray (aqua, TRIM6#).
  5. Centerpunch
    Centerpunch Active Member
    148
    137
    OH / NC
    2017 Prius v wagon
  6. Georgina Rudkus
    3,345
    2,339
    Taylors, SC
    From the dealer's catalog and your photos, it appears that there is only one version of the gray headrest. There were apparently two gray versions of the seats - one being two toned of light and dark gray and the rest being all light gray. So, there is only one version of the gray headrest.
    Hope this helps.
  7. VoltecSynergy
    Portland, OR
    Oh wow! This is a wealth of information. Thank you very much!
    Mine says FA18, and the Toyota Spec page says it's a Dark Gray interior.
    Problem solved.
    I love this forum!
    Thanks everyone!
    Georgina Rudkus likes this.
  8. Elektroingenieur
    2,515
    3,277
    Three Touring
    Are you sure? The Toyota catalog lists six versions of the headrest assembly:
    71910-47150-B0 Dark Gray/Gray/TRIM1#, Fabric
    71910-47150-E0 Bisque/Grege/TRIM4#, Fabric
    71910-47150-G0 Misty Gray/Aqua/TRIM6#, Fabric
    71910-47170-B1 Dark Gray/Gray/TRIM1#, Softex
    71910-47170-E1 Bisque/Grege/TRIM4#, Softex
    71910-47170-G1 Misty Gray/Aqua/TRIM6#, Softex
    The dealer’s catalog (from RevolutionParts) lists only the -B1, -E1, and -G1 versions; I don’t know why they omitted the others.
  9. Georgina Rudkus
    3,345
    2,339
    Taylors, SC
    Maybe I'm wrong, but his (from his photos) I light or Misty Gray.
