2012 non-JBL nav: "System not installed" error when pressing the APPS button, USB not working
Discussion in 'Gen 3 Prius Audio and Electronics' started by Adam Leibovitch, Jan 16, 2013.
  1. Adam Leibovitch
    498
    102
    I installed an audio processor today, the RF 3sixty.3. I already had an amp set up, so there was no new splicing of wires or anything, but the head unit was removed for a few hours.
    Now the menus are very different and when I press the APP button I get a "system not installed" error. The USB port also seems to be unresponsive, not charging or being detected by the head unit.
    The car and settings screens work, phone bluetooth works, but menus and options are different/limited.
    The head unit is also giving a different ID# when connecting to bluetooth.
    I read about a few others who had this issue in a Camry and a V, sometimes it had a wire loose, sometimes it needed a new entune module.
    Has anyone seen this before? Whats the replacement cost of an Entune module? Any ideas are appreciated. I might reboot the car, but I HIGHLY doubt that will work.
  2. V3Peezy
    V3Peezy Junior Member
    SFV
    2013 Prius v wagon
    Were you able to ever fix this? I'm having the same issue.
  3. mustafa
    mustafa New Member
    houston tx
    Same here....similar issue
    Any update?
  4. Robert Morgan
    Robert Morgan New Member
    St. Louis, MO, USA
    Having the same issue as well. Any update?
    Rob
  5. Slammed
    Slammed Junior Member
    Go-to the website download the most recent update, put it on USB and then plug it into the USB in your car, usually in the center console, then go-to radio and run the update
  6. prius8654
    prius8654 Junior Member
    72
    Have a link to the web location to get the latest update?
