2012 PIP Charge Plug Tight
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Feb 2, 2014.
  1. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    We had a few days below Zero the last month. Now the last 2 weeks it is hard to push the charge cable Plug into the car. No matter if you hold the release or just push until it clicks in, it's Hard to get it to connect.
    I can not see anything in the way or out of the ordinary. It used to be very easy to connect.
    Anyone else have this problem.
  2. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    I noticed something similar. Must be the recent cold snap and how it affects plastics.
  3. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Sorry, Just noticed another Thread was already started.
    I'll check the O-ring in the plug and re-seat or remove it.
  4. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    If nothing else, try a bit of WD-40 on the mating parts.
  5. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    WD-40 is a solvent, and will eat plastic. Use a silicone grease, for example dialectric grease.
  6. bisco
    52,849
    is it the stock unit or aftermarket? i haven't had any problem, but the coldest i've charged in is about 15 degrees.
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Better would be a silicone or teflon spray that goes on dry. Any grease (or an oil like wd-40) will attract dirt and eventually make the problem worse. I get silicone spray cans for about $4 at my local auto parts store to periodically lubricate the door seals to stop squeaks. I use a dry teflon lube on my motorcycle chain.
  8. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Removing the O-ring in the handle FIXED the problem of pushing the charge cable into the PIP.
  9. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    Seems like this is becoming an issue with the "older" ie 2012 PIP's.
    Since I removed my O-ring two weeks ago- my handle has locked into the car's charge port easily again.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    No problem here, so far anyway.
  11. ny_rob
    1,968
    814
    L.I.- NY
    FWIW- I charge with the OEM EVSE once per day every weekday and maybe up to 3-4times per day on weekends.
    That amounts to 12x per week (x68 weeks I've owned the PIP= 816 uses) for the OEM EVSE.
  12. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Since March 14, 2012, I plug-in once every day at home and twice at work every workday. 365 x 2 years less 37 days = 693 times at home and 2 x 495 workdays = 990 times at work
    So I've plugged my PIP in 1,683 times.
    The O-ring started causing the problem 3 weeks ago when temp dropped below zero. Doesn't look like it has a purpose, except to cushion the pushing in of the cable.
  13. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I imagine it's a rain seal.
  14. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    I don't think so. The ring is in the bottom of the Handle, which is angled down when plugged in. So water wouldn't reach the ring.
  15. ny_rob
    1,968
    814
    L.I.- NY
    Like ukr2 said- "The ring is in the bottom of the Handle, which is angled down when plugged in" which makes it the highest point when actually plugged in. I'm guessing it's a moisture/splash seal of some sort?
