2012 Plug In Advanced EV charge drains quickly- 5-6 miles
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Henrietta, Mar 22, 2018.
  1. Henrietta
    Henrietta Junior Member
    16
    Massachusetts
    I just bought a 2012 Prius Plug in- advanced. It charges up nicely and says I have about 12 mi EV only range at full charge. But it drains so quickly. It might say I have 4 miles left and it's gone after a mile. Do I need a new battery? It only has 40K on it so the battery is under warranty. It's so frustrating because I bought the thing for the extra EV for short drives around town.
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    The indicated EV range is only an estimate, based on your actual driving habits as the car learns them. While 5-6 miles sounds low, it could be reasonable if the temperature is below 30F. Also, keep your tires pumped up high, I keep the front at 40 psi and the rear at 38.
    #2 Pluggo, Mar 22, 2018
  3. hill
    9,026
    Welcome!
    One of the recently discussed things here was that the traction battery warranty doesn't guarantee full/new range until the end of the warranty. It sure seems like it SHOULD be that way, but unless a manufacturer says you will have X amount of battery capacity % at the end the warranty - or miles driven, well, you only have a warranty issue if the traction pack is a warning code that relates to the traction pack. The good thing is, you will find that you have more range once the weather warms up a bit because batteries, like the ice, are not as efficient in colder or rainy weather. On top of that, you have variables such as elevation changes & how heavy footed a driver is.
    52,820
    hi henrietta, welcome to the pip club!
    it sounds like your car has a problem. right now, i'm getting about 11 miles around town with careful driving, and the indicator matches what i'm getting.
    that isn't always the case if you do a lot of different types of driving, but it shouldn't't be too far off, and 4 miles disappearing to one around town doesn't sound right.
    where did you buy it, and do you know the history?
  5. Henrietta
    16
    Massachusetts
    Thanks- I was worried it was a lemon (and I bought it used from a dealer but didn't pay the $2000 for extended warranty because I thought EV that came with it was enough.). I did just get the car yesterday. It was 40 today and I'm pretty sure tires are okay but will check pressure. Meanwhile, I'll give it some time and see how it goes. My average today was 110 for 20 miles so that was great. If the EV range with the traction battery only is still is really low mileage, I may contact Toyota.
  6. bisco
    52,820
    2 things: toyota doesn't care unless you have illuminated dash warning lights.
    B) give it a full charge, and take it out on 30mph back roads. see how far she goes before the engine comes on.
    jerrymildred likes this.
  7. Henrietta
    16
    Massachusetts
    I bought it at a dealership, it was a trade in. Single owner. 40K. But are you saying that Toyota will only look at it if there is a code?
  8. hill
    9,026
    Yep, sad but true.
  9. Henrietta
    16
    Massachusetts
    I'll try that tomorrow.
  10. bisco
    52,820
    a toyota dealership?
  11. Henrietta
    16
    Massachusetts
    If there were a problem, would I have to replace the traction battery? And what would that run?
  12. bisco
    52,820
    possibly, maybe $5-6000. unless you can find a good salvage. but i wouldn't worry about that, we haven't seen any problems with the pip batteries.
    again, if you bought it from a toyota dealership, there should be a 30 day warranty.
    4est likes this.
  13. Henrietta
    16
    Massachusetts
    We'll see how it goes over the next few days and bring it back if there's a problem. It could be the previous owner didn't use the plug in part that much--- the cord was missing and they are given me a new one.
  14. bisco
    52,820
    so you have not charged it yet?
  15. Henrietta
    16
    Massachusetts
    It was charged at the dealers and when that drained I charged at a public spot in town.
  16. bisco
    52,820
    10-4. did you get two fobs?
  17. Henrietta
    16
    Massachusetts
    yes a Toyota dealership.
    yes
    #17 Henrietta, Mar 22, 2018
  18. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    I live in a hilly area, and my 2012 uses two miles of EV charge just getting up a half-mile hill to a flat area. Always has. The estimated EV mileage assumes careful driving on flat terrain, with HVAC OFF.
    Pluggo likes this.
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    The five big things that shorten my range. Doing all five will really hurt you economy.
    1. Acceleration rate.
    2. Hard stops.
    3. Driving speed.
    4. Temperature. (Sweet spot for me is 70-80°.)
    5. HVAC. (Even just the vent fan on low drops it by about 10%.)
    Tire pressure is also important.
