2012 plug-in basic gets lower miles after full charge in summer
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PriusPlug, Aug 25, 2013.
  1. PriusPlug
    PriusPlug Junior Member
    32
    Hello Guys
    I live in NJ and in summer i am getting a full charge of 8.1 miles. In winter i used to get almost 11 miles. I thought in summer the charge will be even more?. Am i missing something?. Any body run into similar issue?.
    I have 2012 Prius Plug-in Hybrid Basic.
    Thanks....
  2. jnet
    jnet Member
    196
    32
    Are you parked outside? Maybe your car is getting too hot
  3. PriusPlug
    32
    No it is always parked in the garage. Charging happens between 1 AM and 4 AM in the morning. We check the status at around 8 in the morning. So heat is certainly not an issue.
  4. jnet
    jnet Member
    196
    32
    Is your system shutting off prematurely? Make sure you're not using an end timer. Another poster said his end timer is not giving him a full charge.
  5. rcf@eventide.com
    173
    85
    Sedona
    Possibly your charging voltage is lower in the summer and three hours isn't enough for a full charge. Did you try charging without using the timer? (I have the same model and year and get 11+ miles regardless of season.)
    Richard
  6. PriusPlug
    32
    There is a end-timer (4 AM). Starts at 1 AM and supposed to end at 4 AM. Why will this be a problem now when it was not a problem in winter?. I have not changed the settings since I bought the car and set it once.
    Should I increase the timer to may be couple of more hours? like 6 AM?.
  7. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Ar you driving with the AC blasting?
  8. jnet
    jnet Member
    196
    32
    Like the other poster said, the voltage could be lower in the summer. Yeah, I would give it more time and see what happen. The battery is over 200v, so if you're using 120v, the system will have to step up the voltage.
  9. El Dobro
    El Dobro A Member
    7,106
    3,282
    That's what I'm thinking.
  10. markabele
    5,084
    1,782
    Nebraska
    Here is the million dollar question....
    Does your battery on the dash look full after you are done charging?
  11. PriusPlug
    32
    Yes battery is full but it says only 8.1 miles. As for AC goes, no it is not running when the car is parked in the garage in the nite and is being charged. So I don't understand the relevance of that to the full charge miles in the morning before the car is driven out to work.
  12. PriusPlug
    32
    Problem is that after a supposedly full charge in the nite, in the morning i see 8.1 miles in console. it used to be much higher during the winter.
  13. jnet
    jnet Member
    196
    32
    if adding more time doesn't help, bring it back to the dealer. Also, if you have a meter, maybe you could log the outlet voltage and compare it with what you get in the winter.
  14. El Dobro
    El Dobro A Member
    7,106
    3,282
    The readout on the dash is an average for EV use, so if you use the HVAC while driving the car, it's going to be reflected in the average.
  15. 3PriusMike
    3,101
    2,421
    Silicon Valley
    The number shown is some kind of a moving average over some number of past trips and or EV miles driven minus some penalty (maybe 10%) if the heat, A/C or even just the fan is on. Toggle the fan on and off to see the immediate change in the estimate.
    Mike
  16. Flying White Dutchman
    4,376
    313
    its not about the ac running during charging but during driving.
    maybe the prius calculated the ac running into the ev range? and so lowering it
  17. PriusPlug
    32
    Possible. In summer, the AC will be on for some time during the day. So if the EV range isan estimate taking into consideration potential AC Usage then i think its alright. But then the advertised EV range should mention that too :).
  18. pwp1943
    pwp1943 PHEV Afficionado
    51
    Boston
    2013 Prius Plug-in
    Have you checked to see how closely the estimate agrees with the actual number of miles driven in EV mode? If not, then try to drive in EV mode on some 30-40 mph roads without any electrical drain on the system (no headlights, no AC, etc.). See how close the estimate comes to what you see on the odometer.
  19. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Check for engine oil overfill, tire pressure, and 12 volt battery. These things can affect EV miles. Also, if you want to see a bigger number for EV miles (estimate remember) try this trick. Start car, observe EV miles, turn off AC and fan and watch you EV number shoot up (assuming AC and fan were on at last shut down).
    What is your overall mpg and driving style and how fast are you going for those 8+ miles in EV?
  20. bisco
    52,855
    see my reply in your mirror post.
