2012 Plug-In charger problem
Discussion in 'Prime Plug-in Charging' started by JasMayor, Jul 16, 2020.
  1. JasMayor
    JasMayor Junior Member
    22
    South Albany, VT
    2002 Prius
    The charger for my 2012 Plug-In apparently doesn’t work, it has the big red triangle, and the reset doesn’t do anything. I assume it has failed. Comments? Any idea how much a new one costs?
    52,889
    where is the triangle on the charger?
    it can be many things. start by making sure the outlet is good. then find a public charger to try.
    make sure the timer isn't set. test the 12v, does the car start?
    you can find plenty on amazon, etc., couple hundred bucks
  3. JasMayor
    22
    South Albany, VT
    2002 Prius
    Thanks for the reply.
    Just below the On button I think.
    It gets power, isn’t that enough?
    Most in this area are the “other” kind.
    I have used the timer in the past as the triangle doesn’t light up and it charges when schedule.
    > test the 12v,
    It’s good.
    > does the car start?
    Yes.
    I don’t think it is worth that much.
    52,889
    a 2012 plug in prius isn't worth putting a couple hundred bucks into?
  5. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    The red triangle is on the dash, right. NOT on the EVSE. If so there is reason to believe it is the charger, It could be many thing. Check the dagnotic codes first.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    You mean this?
    This is the charging cable (aka EVSE cable). the charger is under the back seat of the car. I think that's what confusing people.
    If the reset button doesn't fix it, then you may need to replace it. I wouldn't try fixing it unless you really know what you're doing with component level electronics repair. They are plentiful on Ebay & Amazon for under $200 new.
    Salamander_King likes this.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    If it is the EVSE (charging cord) you need to replace, eBay is the best place to find a used Toyota OEM EVSE. If you look hard, you can find a quite bargain. If purchased new at dealer or parts store, it is priced way too much. List price $850 ($650 street price). Cable Assembly - Toyota (G9060-47130) | Toyota Parts
    Cheap made in china version of EVSE sells for around $150. Yeah, I have seen a thread by @bwilson4web on repairing EVSE, but that's beyond what I am capable of.
    jerrymildred likes this.
  8. bwilson4web
    16,552
    There are so many multi-voltage, 32-40 A, EVSE out there, I suggest shop and get one that meets your requirements.
    Bob WIlson
  9. JasMayor
    22
    South Albany, VT
    2002 Prius
  10. JasMayor
    22
    South Albany, VT
    2002 Prius
    Recently, the red triangle light on the charging cable (not the dashboard) came on and it would not charge the car’s battery. The service manager at my Toyota dealer said the only problem he had heard about was a loose ground prong on the cable plug. Sure enough it was very slightly loose. I plugged it back in (I had done this before) and this time it worked. The plug is disassemblable so the next time I might take it apart. It was suggested that I might just replace the entire plug, but that would obviously void the warrantee, assuming it has one.
  11. bisco
    52,889
    sharp service manager.
    warranty is long gone, i would repair it
  12. PJN
    PJN New Member
    Rhode Island
    My 2017 Prime will not click into my home or work charging station. At wits end - since I have been plugging in for three years. I am guessing it has to do with the port? Picture attached - seems a little pushed in. No green light or click when I try to plug. Ideas / thoughts re welcome! thx!!!
  13. jerrymildred
    11,517
    14,171
    Tampa, FL
    Hard to tell from a 2-dimensional picture, but they do look a little recessed. Mine measure 0.277" back from the face of the cylinder.
    PJN likes this.
  14. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Does yours have a o-ring and could that be the cause:whistle:?
    Hard to tell in the pic, but look around the outer edge to see;).
    Good luck and keep us posted(y).
    PJN likes this.
  15. PJN
    PJN New Member
    Rhode Island
    thanks for ideas - no o-ring present.
    Jerry - sorry about posting in two different threads - new to this - found the other one - thought it was closer to problem - but it was o-ring which 2017 dont have. My guess is that this may be a dealer issue since chargepoint and home charger dont click - will keep you posted.
    jerrymildred and Raytheeagle like this.
