2012 Plug-in Key FOB Funkiness
Discussion in 'Gen 3 Prius Technical Discussion' started by corystal, Jun 22, 2018.
  1. corystal
    corystal Junior Member
    40
    Los Angeles
    I just got a 2012 plug-in Advanced (w/ tech package) and the key fob won't lock the doors. The LED doesn't light when pressed. Unlock and Panic both light the LED and work. There's also an A/C button, which does nothing (no LED) either... is that even a thing for the plug-in? Is it a programming issue?
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    So the battery is not dead it seems. You can take the keyfob apart (you have to do that when you want to change the battery) and then take the innards out. Then you can press the microswitches that are behind the buttons to see if there is maybe a problem there.
    The LED should light up every time you press the open or close button, even when the car is not in range.
  3. corystal
    40
    Los Angeles
    I took it apart and did that... same result. I thought about bypassing the switches with a wire, but I'm not super savvy with micro-electronics and I'd hate to fry the thing =\
    52,891
    congrats!
    did you only get one fob? there is definitely something wrong with the lock button, could it be stuck down?
    a/c is different. the car needs to be plugged in, and the climate system set correctly.
    all the best!(y)
  5. Francois Yameny
    Francois Yameny New Member
    Baltimore Maryland
    My 2010 Toyota Prius with 232000 miles just have a hybrid system warming check
  6. bisco
    52,891
    welcome!
    uh-oh, could be several things. you'll need to get the codes read. in the meantime, check the 12v health, oil level, hybrid battery cooling fan and intake grille.
    all the best!(y)
  7. corystal
    40
    Los Angeles
    I don't think it's stuck down... The led is not constantly on, and doesn't come on when I press the lock or AC button, but does come on for unlock and panic
  8. bisco
    52,891
    maybe a bad circuit board then...
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Momentary unlock button on the remote may be defective and not making mechanical contact when physically pressed down. The paper clip should close the circuit. There's 2 solder point to close the circuit, making contact to both solder points underneath the pcb board should lock/arm the prius if the momenta/ry button is defective.
  10. corystal
    40
    Los Angeles
    I verified that it's not the button... shorting it does nothing. It's way beyond my pay grade to troubleshoot the board any more than that. Could this be a programming issue?
  11. JC91006
    16,939
    8,647
    If you have AAA higher end coverage (not basic), they'll pay for majority of a new fob replacement (for lost key). Seems you have broken fob
    corystal likes this.
