2012 Plugin - Heat
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by drsacha, Nov 28, 2017.
  1. drsacha
    drsacha Junior Member
    29
    Tempa, FL
    I try turning on the car AC with the remote basically for heating the car in the winter, but do not notice must difference. Seems the remote AC option is just a blower that circulates air in the car for 5 mins. Is it ok to turn the car on, turn on the AC and lock the door from outside. Please guide how you heat the car in winter.
    Data Daedalus likes this.
    52,876
    the remote a/c is cooling only.
    yes, you can start the car, turn up the heat and lock the door with the metal key.
    maybe consider a block heater and/or remote starter.
    Data Daedalus and drsacha like this.
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Or you can preheat with a portable space heater on a good extension cord. Keep it away from anything that can burn or melt.
  4. drsacha
    29
    Tempa, FL
    Hi What is a
    Thanks.
  5. bisco
    52,876
    a device they install in the car, and you get a fob which starts the car remotely, like you're turning on your a/c with the prius fob.
