2012 plugin Prius overheating
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Frank A. Estrada, Jun 6, 2020.
  1. Frank A. Estrada
    Frank A. Estrada Junior Member
    Walnut ca
    2012 Prius plugin. 286k miles original
    Owner. Replaced water pump and thermostat. Car ran great for a few months. Overheating light came on. Water is boiling over and out of reservoir. Fans aren’t coming on. Where is the relay located and fuse location? I’m thinking that’s the culprit. Are there fuses for the radiator fans? Also would the head temp sensor be the culprit?
    Potorap likes this.
  2. Frank A. Estrada
    Walnut ca
    I replaced the head gasket via YouTube guidance. The car runs like a champ again.
    Potorap and Pluggo like this.
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    That's impressive! Which YouTube video do you recommend?
  4. Jordanhiggins2002
    94
    39
    Socal
  5. ETC(SS)
    7,550
    Beware.
    Head gasket failure can sometimes be a symptom of another problem.
    I'm thinking that in some cases, heart failure occurs NOT because of a defective heart....but from eating too many cheeseburgers.
  6. bisco
    52,848
    in gen 3, it is always because of the rings and pistons, leading to clogged egr
  7. ChapmanF
    19,019
    It would probably be hard to construct a shorter sentence that would demand "and this has been established how, exactly?" for so many of its constituent claims.
