2012 Prius 5 - upgrade deck so it will play digital movies while parked?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Shawnna, Dec 15, 2016.
  1. Shawnna
    Shawnna Junior Member
    34
    Covington (near Seattle), Washington State, USA
    I need to make my 2012 Prius 5 be able to play digital movies while parked.
    Does anyone have a recommendation for an aftermarket deck that will allow all of the same functionality as the OEM (back up camera, bluetooth, Music discs, etc) AND play digital movies while parked?
    Thank you in advance for your guidance.
  2. Bham_prius
    Bham_prius Junior Member
    35
    bellingham
    Ya, tape an ipad on top
  3. ChapmanF
    19,055
    Wait, so your 2012 is a 5, so you have the 7 inch nav display that folds down to insert discs, right? I have one of those on a shelf right now, waiting for warmer weather to see if I can transplant it to my 2010.
    It will already play DVDs just fine when parked. I take it by "digital movies" you want to be able to play stuff from some other content source?
    I believe it already can accept a composite video input, but doesn't have a convenient jack provided to connect it. You'd need to get a shielded cable with a yellow RCA jack at one end (preferably balanced, that is, two internal conductors for the tip and shell of the RCA jack, and a shield that isn't just connected to the shell), and three "0.64 III" female terminals (sold by Toyota as part 82998-12870 pre-crimped on short lengths of wire) to connect to the other cable end, for the tip, shell, and shield wires.
    Then you need to get behind the headunit, unplug connector L130, open the secondary retention bar, click those three terminals into cavities 13, 14, and 12 (respectively), click the bar back down, and plug the connector back in. Put the RCA jack end of the cable some convenient place for connecting things ... maybe back in the console where the audio aux in jack already is. (That's where you'll hook up your audio when using a video source.)
    The headunit won't show you the option to select the video in unless it believes you have a source connected. It decides that by looking at resistance between two other terminals of L130 (25 and 11). Those are already wired back to the audio aux jack in the console (terminal 11 is the shield of that cable). There is a switch built into that jack. When nothing is plugged in, there's no connection. When you insert an audio plug, the circuit is closed with a resistance (and the headunit says, "hey, I have aux audio available to select").
    Apparently, when you want to connect video, you close that circuit with no resistance (so, short it), and the headunit says "hey, I have a video source available to select"). Maybe just add a little switch for that.
    Now, I haven't personally tried any of this yet; I found the info here. That post shows an already-made-up adapter you can buy; it just has the necessary cables connected to a male and a female version of L130, so you unplug your original L130 from the headunit, plug it into this thing, and plug this thing in where the original went.
    Either way, you'd then just need a converter to composite video from whatever phone/laptop/player you were going to use, if it doesn't have composite out already.
    -Chap
    #3 ChapmanF, Dec 16, 2016
    Shawnna likes this.
    52,891
    just go to a car audio store and ask, or check out crutchfield.com
  5. Shawnna
    34
    THANK YOU SO MUCH!!! I'm going to print this and the link you included out and take it to the car audio store and have them help me. You seriously ROCK!!:):)
  6. Shawnna
    34
    I did that. It was clear they only wanted to sell me a new unit. Car Toys to be specific.
  7. Shawnna
    34
    So now my question is, does anyone know a reliable car audio installer in the Seattle area who would be willing to help me to this with the instructions ChapmanF has listed above?
  8. Danger
    Danger Member
    175
    22
    Frisco
    Chapman F - Does your oem deck thats going into your car have navi? I want to update my 2010 IV which has NAVI and JBL. I just want a newer OEM deck that has HD radio and such but has to have navi and works with jbl sound system.
  9. ChapmanF
    19,055
    Yes, my car originally had nav (which, in 2010, meant only one choice, the unit with the 7 inch screen, made by Denso). So I wanted to get the 2012 version that's the closest match. In 2012, there's more than one nav choice, the 7 inch Denso or the 6.1 inch Harman Kardon, but I looked for the 7 inch one to keep the look as original as possible. That one's the 86100-47390.
    It still won't be a perfect match; I think the front panel is a lighter shade of grey. I haven't dropped it in the dash yet to see how badly that will stick out.
    It's also definitely not a simple plug and play replacement. They changed the wire harness connectors a lot. Looks like I won't even just be popping the terminals out of the old shells and into the proper positions of the new shells: the terminals used in the shells are mostly different. The 2010 uses a combination of 0.64 II, 1.0 III, and 2.3 II terminals, and 2012 uses a bunch of 0.64 III and some 2.3 II. So even the 0.64 mm terminals are from a different family and probably won't just click into the newer shells. I haven't tried, but my luck isn't usually that good. (There are some 0.64 III terminals in the 2010 too, but only in the connectors for the external XM box, which won't be needed with the 2012 headunit, which has XM built in. Yay, extra space under the driver seat!)
    It would be great if someone sells an adapter harness that works, but I'm not sure how to find out. Otherwise, I'm in for some really tedious wire-by-wire adapting.
    Also, 2012 introduced the JBL 'GreenEdge' technology, which supposedly involves more power-efficient amp and speakers that are specially designed for each other. I'm hoping the headunit won't mind if I just feed its output audio to my 2010, non-GreenEdge amp and speakers. On the wiring diagram, it looks promising enough. The so-far-untested risk is that I get it all wired up, turn it on, it chats with the amp over AVC-LAN and says, hey, that's not a GreenEdge amp you've got there.
    Another thing to bear in mind is that the 2010-11 unit is actually easier to update maps on. You just get the new map DVD and slip it in, done. The 2012 has much more intrusive copy protection where you have to see the dealer for a unique activation number to enter with the new map data. (Another, more human-factors, unquantified risk is whether the dealer techs will even be able to figure out what to do if they need to get a 2012+ activation key for a 2010 car....)
    But it does have HD radio, and play DVDs, and have improved USB music browsing.
    -Chap
  10. Shawnna
    34
    Ok - I want to circle back and let you all know how this turned out. I went to Advanced Sound and Tint in Lynnwood, WA. I showed them this thread with ChapmanF's detailed response. They ordered the parts for me and installed everything.
    Unfortunately, they said this installation would not work with the older iPod Classic we had, and I needed to get an iPod Touch (4th generation) for it to work. So I ordered a used one from Amazon and that one turned out to be a bad unit. I found a brand new one on ebay and got it - plugged it in and it didn't work.
    Had to take the car back to Advanced Sound to troubleshoot it. Keep in mind I'm into this whole thing now to the tune of about $500. They did some rewiring and got it to 'work' - meaning it plays his movies just fine on the OEM screen, without losing any of the functionality of the original equipment. Woo hoo! Thought we were rockin now!
    Today when my son got in the car, his iPod music wasn't showing up on the screen as it's supposed to. Turns out we have to plug the iPod into the USB to make it work the music correctly. So now we have to unplug it and plug it into the special wiring to watch movies, unplug it and plug it into the USP to hear/control music via the touch screen. Seems like this is pretty lame, but it appears that's the best it can be done.
    Anyone have any other insight?
