2012 Prius A/C Stops Working When It Gets Hot Outside
Discussion in 'Gen 3 Prius Main Forum' started by Prius Bud, Jun 12, 2019.
  1. Prius Bud
    Prius Bud New Member
    Los Angeles
    Recently with the heat wave, the a/c in my Prius has been acting up. It blows cold for a bit and then just warm air. The only fix I found to this problem is to turn off the car for a minute and restart it. It gets the A/C blowing cold again for a while longer. I checked the a/c gas pressure and it was good. What could be the problem?
    52,927
    check the inverter pump
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And check to be sure the radiator fans are coming on like they should be.
  4. Stangar
    Stangar Active Member
    174
    175
    Palmdale, CA
    Here’s an easier answer I discovered early in my ownership. If you are in ECO Mode, the A/C cycles off and on with semi-cold air. If you place it in Regular or PWR Mode you get constant cold air.
