2012 Prius - Are all 2012's series 3?
Discussion in 'Gen 3 Prius Main Forum' started by buechler66, Jul 6, 2016.
  1. buechler66
    buechler66 New Member
    Virginia
    I just bought a 2012 Prius, but I'm not certain of the Series it is. Is there a way to confirm this? Are all 2012's the Series 3?
  2. breakfast
    breakfast Active Member
    266
    199
  3. buechler66
    Virginia
    What does the Series number signify? Is it trim level (eg features included)
  4. breakfast
    266
    199
    By "Series", I'm assuming you mean "3rd Gen Prius". The 2012's are all 3rd Gen, and came in different trim levels (Two, Three, Four, and Five)
    You can see what the different trim levels include in lots of places on this site, or at 2012 Toyota Prius Specs and Prices
    buechler66 likes this.
  5. buechler66
    Virginia
    Thank you.
  6. buechler66
    Virginia
    What would change generation to generation? 2010 to 2015 isn't a literal generation. Does it mean a new design? Maybe new battery technology? Or something else?
  7. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    2010 to 2015 is a "literal generation". They all used the same engine and HSD as well as the same body. Trim levels and available options and colours did differ. The generation two used a different engine and HSD, as did the generation one and the generation four, the current model.
    We're talking about the "hatchback" Prius here. Then there is the Prius C and the Prius V, both different cars from the hatchback. The Prius Plugin is very similar to the hatchback, with only slight differences in the body (to hold the larger battery, for example, and the nose is a slightly different style).
  8. buechler66
    Virginia
    Good info. Ty.
