2012 Prius B1473 P0108 P0102 P0113 P0121
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sharnold, Mar 26, 2024.
  1. Sharnold
    Sharnold Active Member
    409
    126
    Alabama
    So new to car JDM engine was installed by a regular mechanic garage @ 217k miles
    Now there's a constant P0108 that refuses to die and a B1473 as well.
    Now granted it looks flawlessly installed and they used every bolt, clip, and retainers stuff I'd toss aside because they are pointless.
    But I believe they disconnected the A/C to install where I do not and refilled themselves so now there's a constant B1473 and yes ( I checked the inverter fuse) it's fine voltage is good.
    Possibly overfilled 134a ruining the A/C compressor?
    As far as the P0108 a new sensor won't clear it.
    As soon as I clear the DTC the code magically reappears as soon as the car is powered up.....ideas?
    I'm getting 5v at power up but showing negative atmosphere pressure that refuses to budge
    Map pressure remains unchanged at all times at 21psi idling or at driving.
    And a whole other slew of P0102 P0133
    P0121 that refuses to clear even after removing the negative terminal on the 12v
    Am I looking for a ground isolation fault from a faulty inverter or am I chasing a bad ground in the harness?
    No intake or vacumn leaks.
    Car does idle and drive flawlessly minus the A/C not working
    Hit me with your ideas?
  2. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Take it back to them and tell them to fix it. They broke it. They should fix it.
    If they can't fix it, they need to take it to someone who can fix it.
