2012 Prius Brake Swoosh Noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sufyant, Aug 17, 2015.
  1. sufyant
    sufyant Junior Member
    39
    16
    2024 Prius Prime
    XSE Premium
    I am looking to buy a 2012 Prius and I test drove it. Everything seems ok except each time I press the brake pedal there is a swoosh noise its as if air is being released from somewhere and I can easily hear it. Is this normal? the car is 95000 km on it. The dealer says it might be a normal hybrid noise. I currently have a 2007 Prius but that does not make this noise. Thanks.
    52,709
    should sound just like the '07. i would have someone check it before buying. i went from an '08 to a '12 and didn't notice anything.
  3. CR94
    CR94 Senior Member
    2,800
    1,231
    Northwestern S.C.
    Are you certain that sound isn't the brake pump running, as it often normally does when you brake (among other occasions).
  4. sufyant
    39
    16
    2024 Prius Prime
    XSE Premium
    Its just a 1 sec air pressure building sound like a woosh is that how brake pump sounds?
  5. Mendel Leisk
    42,205
    A distinctive noise every time you step on the brake? Doesn't sound right, and I think the salesman's just trying to brush off your concerns.
  6. CR94
    CR94 Senior Member
    2,800
    1,231
    Northwestern S.C.
    When you use brakes, the pump intermittently makes the same whirring noise it does when you first open the driver's door from the outside, except for a shorter time. If it's definitely not that sound, I can't guess what it is, and you might have a problem.
